LGM Turbo Group Buy - Start Shipping Out Yeah
Postby theelanman » Wed 11.06.2008, 21:48
my name is wavering......
I want to put a new turbo on mine.....I thought this would be ideal.....
however its turning a little expensive for me....
I can have my OEM unit refurb'd for a lot less and Ive got myself booked in for very expensive respray when I get back from LMC.....
Im meeting paulw at the end on the month so I'll have a look see at his and have a chat with him about it all.......I think thats my deadline date..
sorry to be a fence sitter...but its a £££££££ issue.....
oh and the mrs is still after the new kitchen...... :cry:
Postby lotusgirlmarie » Wed 11.06.2008, 22:03
BASIC KIT
1)
2)
ADVANCED KIT $1052
1) Monty 2.5" inlet, Blue Connectors.
2) MattDon red connectors
3)Ailwyn 2.5", black connectors
STAGE ONE GT2554 KIT $1976.38
1) F1 LOTUS - everything except trashcan > compressor inlet. (Red)
STAGE ONE GT2560 KIT $1976.38
1. Ailwyn 2.5", black connectors
3. Nige - , 2.5" inlet, Red Connectors. But dont believe I actually need the trash can to turbo inlet pipe or the connectors at either end of it. I will however go for the whole kit if that keeps things simple.
4. Paul.P - 2.5" inlet, Black connectors. Jet hot coated downpipe. Polished turbo ( if poss )
5. Dico - 3" inlet, Blue Connectors. Jet hot coated downpipe. Polished turbo (if possible)
6 Richard K -, 2.5" inlet, Black Connectors
7. theelanman -, 2.5" inlet, Yellow Connectors
Please correct me if I misplaced your name in the wrong catagory
lotusgirlmarie
Goddess
Postby XiPHiAS » Wed 11.06.2008, 22:20
I am intested in this stage I and II option, but because I invest alot * of money in my Elan this offer is to early for me.
I made the choice to do the brakes first, so would it possible to order the turbo-uprgade allround Feb 2009?
XiPHiAS
Postby lotusgirlmarie » Wed 11.06.2008, 23:00
unfortunately this may be a one shot deal. I'm not planning on doing a second run as it were. If need be and there is a concensus of everyone involved, the date can be pushed back alittle but again, depending on how far may affect pricing as I"m trying to beat a price hike for steel and for the turbos.
lotusgirlmarie
Goddess
Postby Monty » Wed 11.06.2008, 23:51
lotusgirlmarie wrote:2) advanced kit downpipe, coolant lines, turbo oil feed line, turbo compressor outlet, turbo compressor outlet to intercooler pipe + silicone fittings.
Marie,
Since the #2 kit is now the advanced kit, you haven`t listed the heatshield in your above quote as that was in the original price, so are we not getting this now :? + could i get a gasket too plz
If it`s possible i would like the Downpipe Jet Hot coated too :wink:
BTW any chance on the price on the Basic kit as Da-pinky maybe interested
BASIC KIT
1)
2)
ADVANCED KIT $1052
1) Monty 2.5" inlet, Blue Connectors. Downpipe Jet Hot coated Plz
Postby lotusgirlmarie » Thu 12.06.2008, 00:43
fixed
lotusgirlmarie
Goddess
Postby F1 LOTUS » Thu 12.06.2008, 01:08
Sorry LGM, I'm going to have to miss out on this opportunity as it's a wee bit more costly than I anticipated :cry: However, if I manage to find a buyer for my house before your deadline...
Best of luck with the project :)
F1 LOTUS
Postby Ekapol » Thu 12.06.2008, 16:42
F1 LOTUS wrote: However, if I manage to find a buyer for my house before your deadline...
I hear you Brian, no problem :-)
Added MattRI to the list. (Please confirm 3" or 2.5" inlet)
BASIC KIT
1)
2)
ADVANCED KIT $1052
1)
2. Nige - , 2.5" inlet, Red Connectors. But dont believe I actually need the trash can to turbo inlet pipe or the connectors at either end of it. I will however go for the whole kit if that keeps things simple.
3. Paul.P - 2.5" inlet, Black connectors. Jet hot coated downpipe. Polished turbo ( if poss )
4. Dico - 3" inlet, Blue Connectors. Jet hot coated downpipe. Polished turbo (if possible)
5 Richard K -, 2.5" inlet, Black Connectors
6. theelanman -, 2.5" inlet, Yellow Connectors
7. MattRI - 3" inlet, Blue Connectors. Jet hot coated downpipe. Polished turbo (if possible)
Ekapol
Postby ailwyn » Thu 12.06.2008, 18:36
Please assume that I'm in for 2 x LGM parts 1 x turbo, on hols at the moment so unable to log in very often.
If anything else comes up then please go on the above basis.
Ailwyn
ailwyn
Postby RichardK » Thu 12.06.2008, 18:55
Updated me.
BASIC KIT
1)
2)
ADVANCED KIT $1052
1)
5 Richard K -, 2.5" inlet, Black Connectors. Jet hot coated Downpipe. Polished turbo ( if possible) Delivery to the UK.
RichardK
Postby Dico » Fri 13.06.2008, 09:19
Marie/Ekapol, have you had your heatshield Jet hot coated?
If so, if its possible could I have mine done also? (obviously just add it to the bill)
Postby lotusgirlmarie » Fri 13.06.2008, 18:58
can do. Ekapol's and mine are just mirror polished.
lotusgirlmarie
Goddess
Postby Dico » Fri 13.06.2008, 19:10
BASIC KIT
1)
2)
ADVANCED KIT $1052
1)
4. Dico - 2.5" inlet, Blue Connectors. Jet hot coated downpipe and heat shield. Polished turbo (if possible)
Postby Paul.P » Sat 14.06.2008, 08:03
Marie, ive been reading your project thread again, & see the wastegate supplied with the turbo was not up to the extra boost, so will you be sending the turbo with the wastegate supplied or with whatever you decided to use, or do we have an option ?
Postby lotusgirlmarie » Wed 18.06.2008, 00:08
Paul P. has brought up one more point that i overlooked. The turbos that Ekapol and I have are equiped with 12PSI wastegates. this means that they crack at 12 PSI. Fine if your running the Everst chip or want to go higher but not so good if you wish to run the stock settings. All turbos will come equiped with the 6PSI wastegates unless otherwise specified.There is NO effect on pricing for either of the wastegate options.
The reason that Ekapol and I went with the higher rated gates was that we wanted to go to higher boost levels (over 1 bar) and the 6 PSI gate was struggling to keep closed at that preasure, even with a boost controller.
lotusgirlmarie
Goddess
Postby theelanman » Wed 18.06.2008, 01:15
sorry Im an out......
Im still in for the intake stuff but I need a rewire on the +2.......
its running now and I need to find an MOT...I think this may take all my extra cash....
sorry......
Postby Dico » Wed 18.06.2008, 06:53
Updated with 12psi wastgate option for me please Marie
BASIC KIT
1)
2)
ADVANCED KIT $1052
1)
4. Dico - 2.5" inlet, Blue Connectors. Jet hot coated downpipe and heat shield. Polished turbo (if possible) 12 psi wastgate
6. MattRI - 3" inlet, Blue Connectors. Jet hot coated downpipe. Polished turbo (if possible)
I think I've done right in removing your name Gareth?
Postby Paul.P » Wed 18.06.2008, 07:23
Updated with 12psi wastgate option for me as well, please Marie
BASIC KIT
1)
2)
ADVANCED KIT $1052
1)
3. Paul.P - 2.5" inlet, Black connectors. Jet hot coated downpipe. Polished turbo ( if poss ) 12psi wastegate
4. Dico - 2.5" inlet, Blue Connectors. Jet hot coated downpipe and heat shield. Polished turbo (if possible) 12 psi wastegate
Postby RichardK » Wed 18.06.2008, 07:30
BASIC KIT
1)
2)
ADVANCED KIT $1052
1)
5 Richard K -, 2.5" inlet, Black Connectors. Jet hot coated Downpipe. Polished turbo ( if possible) Delivery UK. 12psi wastegate.
RichardK
Postby Nige » Wed 18.06.2008, 10:55
I have permission from the financial controller :D but like some others my preference is to source the Turbo in the UK as import duty and VAT (which will be payable even if US taxes have been paid) will add significantly to the cost, the option offered by Paul Watkins is therefore an attractive one. I'm therefore in for an advanced kit and have updated the list accordingly.
BASIC KIT
1)
2)
ADVANCED KIT $1052
3) Ailwyn 2.5", black connectors
4) Nige 2.5" inlet, Red Connectors. Downpipe Jet Hot coated and turbo gaskets please.
1)
2. Paul.P - 2.5" inlet, Black connectors. Jet hot coated downpipe. Polished turbo ( if poss )
3. Dico - 2.5" inlet, Blue Connectors. Jet hot coated downpipe and heat shield. Polished turbo (if possible) 12 psi wastgate
4 Richard K -, 2.5" inlet, Black Connectors. Jet hot coated Downpipe. Polished turbo ( if possible) Delivery UK. 12psi wastegate.
5. MattRI - 3" inlet, Blue Connectors. Jet hot coated downpipe. Polished turbo (if possible)
Back in Blighty
Nige
