unstuck wastegate, turbo seems to have gone
Postby mikeydude » Fri 30.11.2007, 22:37
Ah.....I have only just seen this post...hold it there, do not paint it, there is no need...It is Zinc plated (drab olive passivated) that's why it is a dark colour.....get some Cream metal polish and rub the hell out of it....it won't seem to be doing anything for a while then it will shine like Chrome!!!!
Autosol is the best one.
In theory it's less resistant to corrosion after the passivation is removed. but I have found it to be fine.
Try getting a little buffing wheel set for a dremil type tool..ten off you go....most Zinc and Nickel plating will polish up like chrome.
That's how these classic car guys do most of there stuff...it's not all re-chromed like we think..its just the original plating polished.
mikeydude
Postby Specky » Mon 04.08.2008, 17:54
Waste gate got stuck today... I think... Wierd Turbo whistle too..
0.75 Bar.. :shock:
When you do the wiggle how much play should you have... or what are the extrmities...
Postby Specky » Mon 04.08.2008, 19:01
Buggeration...
Bottom bolt rounded already.... :twisted:
and I've just dropped my 8mm combi spanner in the lower heat shielding.. :evil:
Postby GeoffSmith » Mon 04.08.2008, 20:45
If you release the capsule, you should be able to rotate the wastegate shaft over almost 90°, so there should be fair bit of movement and it should be free and easy unless there's an 8mm spanner jammed in there.
Postby Specky » Mon 04.08.2008, 22:37
GeoffSmith wrote:If you release the capsule, you should be able to rotate the wastegate shaft over almost 90°, so there should be fair bit of movement and it should be free and easy unless there's an 8mm spanner jammed in there.
I don't get it... :roll:
I've undun the three bolts..
Am I just moving the diapham back and forth...
or trying to rotate the shaft...
or move the other end back and forth...
idiots guide please... the Wiki didn't help..
Postby GeoffSmith » Mon 04.08.2008, 22:50
You're trying to rotate the shaft - if you pull the whole of the wastegate capsule plus bracket away from the turbo (towards the front of the car), you should then be able to move it (side to side). Thinking about it and looking at the picture, you might be better of removing the hose to the capsule as well. When I did mine on the car, I wasn't sure how much it had to move and I thought I had freed it pretty well. It was only when I was porting the wastegate (off the car) that I realised how far it could move. It was also pretty sticky in places and took quite a bit of wiggling to free it off completely.
Postby Specky » Mon 04.08.2008, 23:25
It's moved...just..
It's not free by no means... it's jamming solid in numerous places...
it worries me it was fine one day and biffed the next... is it possible for internal failure of the waste gate...
I'll have one more go...
The car overboosts with a code 31, but the power isn't there..
I like my 0.5 Bar boost...
You boys must scare yourselfs silly with 3 bar boost
Postby Specky » Tue 05.08.2008, 00:37
Good news...
and bad...
First the good...
the rod nows moves freely... :D
full range of movement..quick response...0.5 bar boost... normally turbo whistle...
Now the bad...
I had to use a WD40 equivilant..moving it back and forth alone would not release it...my car smells like a BBQ... :cry:
I did use a small paint brush with some copper crease to keep things moving thou
Cheers Geoff.. taking the pipe off makes things easier and allows more access behind the shield to lube up... :shock: and admire the oxidation process
Postby tigerdog » Tue 05.08.2008, 07:04
Specky wrote:the rod nows moves freely... :D
Great to hear! Congrats on a job well done. But for any BBQ related items, make mine medium-rare. :-D
Postby Doug » Tue 05.08.2008, 08:03
Specky wrote:Good news...
and bad...
First the good...
and I thought the rest was going to be something like:
". . . too bad it sits in my hand broken from the assembly"
:smt044
good job -- I'll ave a burger too . . .
Postby Paul.P » Tue 05.08.2008, 08:03
I know Gerald at GST uses some special sort of very high temp grease for this job, & reckons it should last between services ( 1yr at least ), i'll try * find out what it is next time i'm down there ?
