ME
ME
ME
ME
ME
PIPEXH4 please (2.25", no cat or front silencer)
ME
ME
ME
ME
ME
Enright wrote:Chris,
Usually (using a bigger exhaust and the standard or ESM chipped ECU) it's a lottery - you can never quite tell whether or not you'll get fuel cut-off due to excessive boost creep.
But with the BBR having a fuel-cut defender I think you're less likely to see cut-off due to boost creep. However, do not for one moment think that's a good thing.
You're still likely to GET boost creep, but your fuel-cut has already been inhibited so there's nothing to protect your turbo.
This means that the increased airflow clould overspeed the turbo and blow it to bits. Seriously.
Mind you, until that happens you'll have a big grin on your face cos it'll go like a rocket!
It's a case of what's more important to you I guess.
Personally, after having the exhaust fitted I would plumb it back in as standard and drive it like you usually do to see if you hit fuel cut-off. If not, put the BBR back in, and if you do then leave it out until you can get the wastegate ported for safety's sake.
chris.t wrote:Thanks Ailwyn, I guess I really need to know from anyone who has a BBR fitted inconjunction with a 2.25" bore exhaust to hear there thoughts on the subject.
Any idea on delivery for these systems from date of order?
Cheers Chris
ailwyn wrote:Neil,
As I understand it BBR is a 2 part system, the MBC which sets the boost level (bypassing the BSV) and the FCD wich stops the ECU seeing any boost above "x" psi.
IIRC Dico had a (more) bodged setup - the FCD, bypassed the BSV, but no MBC so the turbo was just boosting without limit.
Monty wrote:BTW, Just to let Piper know that on the Peco system that all the welds were Stainless and the Flexi is also Stainless, the only part that wasn`t is the triangular flange
chris.t wrote:Monty wrote:BTW, Just to let Piper know that on the Peco system that all the welds were Stainless and the Flexi is also Stainless, the only part that wasn`t is the triangular flange
Is it necessary to have flexi. I talked to lakeside about this and they said that when they have any failures its generally at the flex. So it would be better to be solid throughout.
Monty wrote:chris.t wrote:Monty wrote:BTW, Just to let Piper know that on the Peco system that all the welds were Stainless and the Flexi is also Stainless, the only part that wasn`t is the triangular flange
Chris, the lakeside are talking a load off rubbish. The Stock system is well known for cracking at the down pipe hence the reason the aftermarket fit a flexi to prevent this+ Peco gave a life time garrantee (which obvioulsy is a waste of time if they go bump) so i`m sure they wouldn`t fit a flexi if they thought it was going to fail.
