by dapinky » Tue 02.09.2008, 03:14
It is my understanding that shocks should be married to specific springs (length/rate), and any change in any variable will have an effect on any other.
ie, if you fit stronger springs, to get the same ride height you need to lower the shock platform, or use shorter springs. But as the shock will have been designed (hopefully) for the original springs, either option will allow the stem of the shock to have a shorter range of movement than its maximum, which will have an effect on the amount of 'wallow' you get.
In simple terms, if a shock has a movement of say 5" with stock springs, by using shorter ones, you may have a full movement of only 4" (the same as if you drop the platform by an inch to compensate for extra strength in the spring).
This will have little effect on a road (usually), but on a track, with full body roll and high G forces, the movement of the shock could be the limiting factor???
As it gets to maximum extension/compression, there is no more absorbing of shocks, and just body roll - like if you had solid bars instad of hydraulics.
I'm not suggesting that any of the shocks in use would necessarily suffer from this phenominon, but i have completely different length units for the track dolly with short, hard springs (koni) than for the road car with medium length ones (spax) - and stupidly long thick bilsteins on the rally car.
When i put the Bilsteins on the track car with short springs I couldn't get the platforms high enough to allow the spring to touch the top mount on full travel on the rear axle, and found both springs popped out of their mountings at Llandow circuit with interesting results (a 'brown trouser' moment for my passenger more than me).
I'm not wanting to state this as fact (i'm not a dynamic engineer), but just as a few random thoughts.
