Look forward to seeing the set up at Hethel
bobbrown wrote:As for the Wilwood 15/16" kits using the powerlite and dynalite calipers I have no idea OK they are going to be lighter but by how much I do not know probably not that much the discs weigh 3.5kg and 4kg respectivly you then have to add in the bolts (hat to disc) + the hat/bell. We could assume there is only a small differance in caliper+pad weights. So I would say the two piece disc kit probably saves 1 to 2 kg over the single piece disc.
Elanlover wrote:I'll be interested in knowing if i could use this setup (calipers and mounting bracket) with the existing rotors that Brian spec'd for the original Wilwood upgrade (I've got 16" wheels).
Nige wrote:I think it will be a very popular and worthwhile upgrade, particularly for those who haven't yet upgraded.
It's on my project creep list
CJ101KT wrote:I am also interested in this kit for my stock brakes I have under my S2 16" wheels ... if these are available before the NEC Classic Car Show I would be so happy and even promote your kit when my cars on the stand ...
