I'm sure a yellow one will fill up your new drive way quite nicely.
nitroman wrote:Have any of yous' in the UK thought about whether that is currently economically viable?
Doc Fizzix wrote: I would like to say that I will have another Elan someday since it is truly the best car I have every had the pleasure to drive but I am not sure I could take Fubar ripping me a new one for getting my third Elan (LOL)
Doc Fizzix wrote:and then a complete 2.5 inch exhaust system.
Doc Fizzix wrote:Ok, it has been some time since I have been on this thread.
UPDATE: I had a small vibration in the motor that I could feel in my seat but only at an idle. I found that my right side motor mount was bad and after replacing thing are much better BUT there is still the smallest vibration that I can feel.
Possible cause: In discussion with my tech and with Dave Bean we are guessing that the lighter flywheel may be the culprit. Because the flywheel does not have a large amount of rotation inertia the power stroke of the motor is more prevalent and amplified at lower RPMs. Once the RPMs are bouught up the motor is as smooth as can be with no vibration at all.
Doc Fizzix wrote: I do not think the difference makes the aluminum flywheel an option for a daily driver, it is more for the drag strip and that is not my driving style.
tigerdog wrote:A lighter flywheel and stiff clutch make for more "interesting" daily driving, since the lower rotational inertia seems to make the car easier to stall when trying to take off at a sedate pace. Does rev (and lose revs when shifting) more quickly, though.
Specky wrote:Does the fly wheel come balanced...
or is there away to balance it in situ...
Doc Fizzix wrote:Specky wrote:Does the fly wheel come balanced...
I think it comes balanced from the factory but I will have to look into that again. I know that we had mine balanced without the pressure plate and then again with the pressure plate to make sure it was set-up as close to balanced as possible.
Specky wrote:I wonder if it's worth clocking the fly wheel when you remove it... or is it keyed...
Doc Fizzix wrote:Specky wrote:I wonder if it's worth clocking the fly wheel when you remove it... or is it keyed...
What do you mean by "clocking"?
The flywheel is not keyed.
GeoffSmith wrote:It sounds like the lower inertia of the flywheel has made the control loop (engine speed signal -> ECU -> fuel injectors) go sufficiently underdamped that the engine now hunts. It would be interesting to see an Elanscan run.![]()
Doc Fizzix wrote:Does anyone have plans for a USB connection to the ECU? Then I could us my Mac in Winders mode.
