HJ2 wrote:Chris P, that looks Crisp!
I think u meant crispy
chrisP wrote:Hi HJ2
I made a perspex version ages ago, its bolted to the softtop cover and works quite well - I couldn't make it too tall as it would get in the way of using the soft top
HJ2 wrote:Well, as far as engineering goes without a toolshop: This looks great!
Paul.P wrote: it sounds quite fiddly trying to bend perspex with a blowtorch, very comendable job with the tools available !
chrisP wrote:Good play on names.....![]()
James The perspex is 6mm thick tinted, it was an off cut from a local plastics company. I bent it with a blow torch (carefully) and welded up some aluminium brackets so that I didn't have to drill into anything. Only using slightly longer bolts to attach to the soft top cover. Picture below
I'll sort out some dimensions for you.
Paul, I see what you are saying with your design, if I had a machine shop I think I would make it adjustable, I just don't have the tools to engineer it.
......and I think a matia one would reduce rear view vision too much..but mainly I am a tight arse BFG in the BRG wrote:Hi Peeps,
I was thinking of doing a wind deflector out of 5mm acrylic if anyone has a Matia deflector can you let me know the dimensions - Enright, CJ101KT?
I was thinking along the lines of 450mm deep x 930 at the bottom reducing towards the top - just to give it an angle for asthetic reasons with rounded corners - the only downside to this would be the loss of the hood storage area which is useful as a cubby hole - although I could do a cutout between the hood stowage cover catches, or 260mm x 930mm again reducing towards the top, and the deflector sits above/level with the hood stowage cover.
Basically I am a tight arse and don't want to pay for a Matia one......and I think a matia one would reduce rear view vision too much..but mainly I am a tight arse
lotos wrote:I love the idea of it's there when you want it, and slides down when you don't... very nice.
