wind deflector advice please
Re: wind deflector advice please
Postby theelanman » Wed 05.11.2008, 01:17
HJ2 wrote:Chris P, that looks Crisp!
I think u meant crispy :-D :-D :-D :-D :-D :-D :-D
Postby Paul.P » Wed 05.11.2008, 08:10
chrisP wrote:Hi HJ2
I made a perspex version ages ago, its bolted to the softtop cover and works quite well - I couldn't make it too tall as it would get in the way of using the soft top
Good effort Chris, we made ours to pull out so as we could get them higher, then when not in use, drop down to a similar position where yours is, & the brkts we're mounted on the bulkhead behind the seats.
Postby chrisP » Wed 05.11.2008, 13:31
Good play on names..... :D
James The perspex is 6mm thick tinted, it was an off cut from a local plastics company. I bent it with a blow torch (carefully) and welded up some aluminium brackets so that I didn't have to drill into anything. Only using slightly longer bolts to attach to the soft top cover. Picture below
I'll sort out some dimensions for you.
Paul, I see what you are saying with your design, if I had a machine shop I think I would make it adjustable, I just don't have the tools to engineer it.
chrisP
Postby HJ2 » Wed 05.11.2008, 13:43
Well, as far as engineering goes without a toolshop: This looks great!
Postby rival » Wed 05.11.2008, 18:15
Chris,
Thanks for the additional photo. That's a real tidy job. I like the fact that you still have easy access to hood stowage space.
I wonder whether my wife's creme brulee blowtorch will be up to the job... :D
James
rival
Postby HJ2 » Wed 05.11.2008, 18:20
Hmmm! The smell of cramelised perspex! :lol:
Postby Paul.P » Wed 05.11.2008, 18:59
HJ2 wrote:Well, as far as engineering goes without a toolshop: This looks great!
Have to agree with that !, your brkts look a lot more technical than ours ever were :lol: , & it sounds quite fiddly trying to bend perspex with a blowtorch :shock: , very comendable job with the tools available !
Postby dapinky » Wed 05.11.2008, 19:15
Paul.P wrote: it sounds quite fiddly trying to bend perspex with a blowtorch :shock: , very comendable job with the tools available !
I have to agree......
....however, the cleanest way i have found to bend perspex is to put it in the oven!
Obviously, not at the same time as your tea, and usually when the wife is out (some people have no sense of humour :roll: ) like you would for heating the ring gear to fit onto a flywheel, but i digress.....
something like a 220 heat, put the sheet of perspex on a flat board and leave the bit you want to bend overhanging - it will soon go floppy and bend evenly under gravity - this is an extremely crude description, and i usually make a wooden mould/former, but you get the idea.
Leave it to cool without quenching it and you should have a near-perfect item.
Postby HJ2 » Wed 05.11.2008, 20:36
I used to do it like this:
Build a bending bench (is this correct english?) out of plywood and door hinges.
At the bend point use an aluminum U-profile.
Put a Wolfram ribbon connected to a spring to keep tension and heat it up with use of a transformer.
Perspex on bench, heat up and bend in right angle, cool down... Tadaaaaa!
HJ
Postby CJ101KT » Thu 06.11.2008, 00:15
Stick with the one that Classic additions do ... best ive seen around really ...
CJ101KT
Postby chrisP » Thu 06.11.2008, 14:00
I'm not sure if your wifes blow torch will really cut it on this one :-D
The reason I did it like this was so that you could get to the hood stowage area - ideally I would have liked to have the perspex slightly taller.
The brackets were a pain, first I tried them as just a bent bit of 4mm aluminium, but there was a resonance problem once you got up to speed, so I welded a reinforcement along one side of each one.
The perspex was too long for the oven (about a metre) so the only thing I had was the torch and some long bits of wood to bend it with - HJ's idea sounds good though.
chrisP
Postby Neil D. » Fri 07.11.2008, 13:02
chrisP wrote:Good play on names..... :D
You can use makrolon, it will bend cold... Simple..
http://www.makrolon.com/BMS/DB-RSC/Makr ... id/home_en
use it at work all the time
Neil
S2 # 541
Neil D.
Postby chrisP » Fri 07.11.2008, 13:23
Neil
Would it not bend back or flex with the force of the air once driving?
chrisP
Postby BFG in the BRG » Tue 18.11.2008, 15:58
Hi Peeps,
I was thinking of doing a wind deflector out of 5mm acrylic if anyone has a Matia deflector can you let me know the dimensions - Enright, CJ101KT?
I was thinking along the lines of 450mm deep x 930 at the bottom reducing towards the top - just to give it an angle for asthetic reasons with rounded corners - the only downside to this would be the loss of the hood storage area which is useful as a cubby hole - although I could do a cutout between the hood stowage cover catches, or 260mm x 930mm again reducing towards the top, and the deflector sits above/level with the hood stowage cover.
Basically I am a tight arse and don't want to pay for a Matia one :banana: ......and I think a matia one would reduce rear view vision too much..but mainly I am a tight arse :roll:
Alas soon to be Elan-less
BFG in the BRG
Postby CJ101KT » Tue 18.11.2008, 17:34
BFG in the BRG wrote:Hi Peeps,
You have a PM :mrgreen:
CJ101KT
Postby *LUCA* » Thu 05.02.2009, 17:34
It's very very nice the ChrisP's wind deflector model, compliments.
Here there is my wind deflector prototype. It is almost finished, ready to receive an electric motor (the same of the electric window) and finishing leather.
The rear panel will be covered with the same interior leather.
I chose a dark color for when I want more privacy. With softop closed and wind deflector on the cockpit becomes more intimate and without that annoying feeling of having the eyes of him who is behind you in the traffic.
*LUCA*
Postby Gee0 » Thu 05.02.2009, 17:43
now I love the wind deflector, Very nice
Gee0
Postby lotos » Thu 05.02.2009, 21:00
I love the idea of it's there when you want it, and slides down when you don't... very nice.
lotos
Postby tigerdog » Thu 05.02.2009, 21:19
lotos wrote:I love the idea of it's there when you want it, and slides down when you don't... very nice.
Agreed! Could you please post pictures or diagrams of the mechanism you made and how it mounts? Great job! :-D
Postby HJ2 » Thu 05.02.2009, 22:11
hohly canoli!
Respect! :banana:
