Yella Fella
Re: Yella Fella
Postby tweetdriver63 » Mon 03.11.2008, 06:31
Doc Fizzix wrote:Why not file the "Wilwood" off, re-spray black, and then add the yellow lotus logo (that would look cool) :banana:
I like the idea of just the Lotus logo. It would be a lot easier to paint the willwood with black caliper paint.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Re: Yella Fella
Postby Doc Fizzix » Mon 03.11.2008, 18:14
tweetdriver63 wrote:I like the idea of just the Lotus logo. It would be a lot easier to paint the willwood with black caliper paint.
I still say you could file the "Wilwood" off, then paint with black caliper paint, and then add the Lotus logo :D
Doc Fizzix
Re: Yella Fella
Postby Elanlover » Mon 03.11.2008, 18:19
Too bad you can't use the other side where there's no Wilwood logo at all :smt102
Re: Yella Fella
Postby nitroman » Tue 04.11.2008, 00:19
That probably would look best, but all those things are a lot of work. The piston "buldge" is 40mm across, which would allow for Lotus roundels placed 2 per caliper, if the 'Wilwood' was removed.
nitroman
Re: Yella Fella
Postby nitroman » Fri 07.11.2008, 02:09
Powder coated "Bad Boy Yellow" (matches Norfolk Yellow). The 2 TopEnd supplied air-pipes were done as well. I took the opportunity to saw off enough of the bottom TopEnd piece so that it no longer puts ruinous pressure against the main water pipe. There had been cardboard placed there by the former owner to protect the water pipe.
IMG_0902 (Small).JPG (29.06 KiB) Viewed 6304 times
IMG_0900 (Small).JPG (38.28 KiB) Viewed 6514 times
nitroman
Re: Yella Fella
Postby Doc Fizzix » Fri 07.11.2008, 04:43
nitroman wrote:Powder coated "Bad Boy Yellow" (matches Norfolk Yellow). The 2 TopEnd supplied air-pipes were done as well. I took the opportunity to saw off enough of the bottom TopEnd piece so that it no longer puts ruinous pressure against the main water pipe. There had been cardboard placed there by the former owner to protect the water pipe.
:shock:
That is cool as SH*T! :banana:
Doc Fizzix
Re: Yella Fella
Postby lotos » Fri 07.11.2008, 18:46
Man I can't wait to see an engine bay picture with those parts on. :smt055
lotos
Re: Yella Fella
Postby GeoffSmith » Fri 07.11.2008, 19:54
Superb job as always Matt. Did you paint the raised Lotus lettering before powder coating?
Re: Yella Fella
Postby Enright » Fri 07.11.2008, 21:38
It looks great, but you left the surplus lugs on! :?
Re: Yella Fella
Postby GeoffSmith » Fri 07.11.2008, 21:53
:smt045
Some time ago Doug wrote:1. Matt, don't forget to grind down the other two screw holes that project up and do not connect to anything -- they can be ground flush with the top deck!!
Re: Yella Fella
Postby lotos » Fri 07.11.2008, 23:44
Maybe he has plans for those holes... like adding accessories.... a mirror to check out your hair while working under the hood?
But it's likely he just wanted another spot to insert a shiny stainless bolt.
lotos
Re: Yella Fella
Postby GeoffSmith » Sat 08.11.2008, 00:20
lotos wrote:But it's like he just wanted another spot to insert a shiny stainless bolt.
:smt044 :smt045
Re: Yella Fella
Postby nitroman » Sat 08.11.2008, 03:41
Note the notch I cut out of the mounting base. I installed these in the car tonight. You'll be able to tell why I cut this notch when I take pictures in the daylight tomorrow. Things like this perplex me somewhat and make me think perhaps someone just mailed in dimensions and the product was never test-fit in an actual vehicle prior to being produced.
The "right" color makes a huge difference over just having a generic yellow. These really look like factory pieces now, maybe even enough to fool your testers in California. Certainly it costs no more to have these powder coated locally (TopEnd charges $140!) where you can pick the matching color from amoung 300 or so colors; unless of course, you prefer the base color of black.
The lugs on the cam cover never bothered me, plus Blair raised a good point about the hole being deeper than the surface, although that could have been filled before it was powdercoated. You never know what you might have to bolt to the top of the engine!
GeoffSmith wrote:Did you paint the raised Lotus lettering before powder coating?
Actually its just polished. I intended to paint the letters black but I think I'll install it in the car 1st to see how it looks.
nitroman
Re: Yella Fella
Postby Elanlover » Sat 08.11.2008, 04:04
Matt, with regard to the Lotus lettering that you polished, did you paint the entire cover then sand/polish down the letters to reveal the metal or did you use some other method?
Re: Yella Fella
Postby nitroman » Sat 08.11.2008, 04:38
Elanlover wrote:Matt, with regard to the Lotus lettering that you polished, did you paint the entire cover then sand/polish down the letters to reveal the metal or did you use some other method?
I used a power sander with 180 grit paper. It's just bare metal. It was polished after being powder coated, as the coating covered everything topside.
BTW I'm going to try and relocate the boost gauge transducer to the firewall. I just hate that pink rubber cover!
nitroman
Re: Yella Fella
Postby tweetdriver63 » Sat 08.11.2008, 05:31
Why not just paint the pink cover yellow, too? :?
'91 Elan SE
tweetdriver63
Re: Yella Fella
Postby nitroman » Sat 08.11.2008, 17:33
Painting rubber then placing a metal-spring tensioner over it? I think the stress will make the paint crack & peel off. I'll give it another look, but it seems like something that will just look ugly & like a "shade-tree mechanic" solution in a very short time.
nitroman
Re: Yella Fella
Postby tweetdriver63 » Sat 08.11.2008, 18:36
nitroman wrote:
tweetdriver63 wrote: Why not just paint the pink cover yellow, too? :?
I don't know if they have the right color for you, but you can take a look at Plasti-dip, and just layer it with a different color rubber. Their yellow probably doesn't match, but black would look good, and your local hardware store probably has the black on their shelf (Lowe's has it here). I had to special order the red for my car, but it has held up well on my intake pipes (used the spray version for those) and on the oil dipstick handle (used the dip for that).
'91 Elan SE
tweetdriver63
Re: Yella Fella
Postby nitroman » Sat 08.11.2008, 20:28
The latter is my attempt at showing the interferrence with the cooling hose, but without a before picture it is almost meaningless. Trust me though, it was bad.
IMG_0921 (Small).JPG (60.88 KiB) Viewed 6115 times
IMG_0913 (Small).JPG (69.3 KiB) Viewed 6114 times
IMG_0938 (Small).JPG (33.85 KiB) Viewed 6115 times
nitroman
Re: Yella Fella
Postby nitroman » Sat 08.11.2008, 20:30
And here is sort of an indication of the look when I do install more pieces, but I have millions more pieces than this to put on.
IMG_0924 (Small).JPG (51.85 KiB) Viewed 6109 times
IMG_0929 (Small).JPG (54.67 KiB) Viewed 6111 times
nitroman
