Hi.
Re: Federal Tyres........
These Tyres are generally regarded as a semi-budget brand comapred to branded manufactures Dunlop, Yoyo, Pirelli etc... although they are not the cheapest.
The SS35 is a more everyday run of the mill tyre,
The SS95 is more sport perormance orientated, and the RS 595 threaded here is more track day / fast road.
Most Tyres come with a "Treadwear" Rating, this is a requirement in the USA where a tyres wear rate is required to be printed on the sidewall.
In short you can look at any tyre and see what this number is, which can (but not always) help you understand it's characteristics:
EG: The infamous Track day tyre TOYO R888 has a rating of 100.
A Federal SS35 is approx 350 - 400 from menory and the more sporty SS595 i about 280.
Yes the smaller the number the softer the compound, and typically a tyre with 400 will last twice as long under the same conditions as a 200.
There are some differences though, and rubber compiund does play it's part.
A fairly new-ish material called "Silica" which is based on a special silicone rubber mix, is used a lot now by most performance brands, this is very soft and grippy in the wet and also very durable. So the treadwear number may look high 300 but it's characteristcs are good for handling.
I've found this treadwear number very handy when hunting for and chosing tyres and I've had I believe most types of vehicle, drivetrain, and fuel type etc....and have had much success with finding tyres that suit different applications.
PetrolFront wheel drive, front engine 1.6 turbo
Front wheel Drive, front engine 2.5 V6
Front Wheel Drive, front engine 2.3 5 cylinder turbo
Rear wheel Drive, Rear/Mid Engined 1.6 & 2.0 Twin Cams
Rear wheel Drive, Front Engine 2.9 V6 Cosworth
Rear wheel drive, front engine 4.7 litre V8
Rear Wheel Drive front Engine 2.5 Litre 4 cyl
Diesel Front wheel Drive, front engine TDI 150bhp
Tyres on a forum are a bit of a subject as many people have tried and like many different brands and it can become quite a thread???
Any thoughts?
