RayD wrote:With that amount of rust it's a wonder the brake pipes passed an MOT in the last 12 months. If that area of the car is typical you might have to change all the pipes to be on the safe side.![]()
rip wrote:...On a motorway journey, boost creep gives plenty more power. Turbo lag is reduced & the engine is very responsive to a slight increase in throttle opening. At full throttle, boost creep eventually rises to .94 bar at 5200rpm wgen overboost occurs. This is easily avoided by backing off the throttle very slightly without losing much performance so I see no need to port the wastegate.
RayD wrote:One result of searching for boost creep on the web says...
Boost creep: When the boost rises past the set limit.
rip wrote:Dammit, this car is just one step ahead of me the whole time.
rip wrote:The smell of gearbox oil is highly distinctive, so it was probably not the clutch at fault.
rip wrote:I headed across the twisty A507 for an LEC curry .........then I lose drive .......the clutch has let go without warning.........fluid drip ...........the smell of gearbox oil ..........
