Replacement Fans (UK Turbo & NA)
Re: Replacement Fans (UK Turbo & NA)
Postby Freelander » Mon 01.12.2008, 12:50
Oh what the hell indeed - they can be an early birthday pressie (2011)
1.Galsia +
2. Sy +
3. Ailwyn +
4. Ailwyn +
5. Dico +
6. BobBrown +
7. Stef
8. Dapinky +
9. Muley+
10.Woody
11. Ghost2
12. Trig +
13. Richard K +
14. Router +
15. Holty +
16. rip +
17. Geoff +
18. Freelander +
19.
20.
1990 SE Turbo - Silver - Work in Progress (Slowly)
'Go slow now - go fast later'
Freelander
Postby Gordon » Mon 01.12.2008, 13:31
In line with Gasia's comments, I'll make up fitting kits for all the fans.
I'm just waiting for a price on 40 fans (20 pairs) - I'm just trying to find grommets for a sensible price!
1.Galsia +
2. Sy +
3. Ailwyn +
4. Ailwyn +
5. Dico +
6. BobBrown +
7. Stef
8. Dapinky +
9. Muley+
10.Woody
11. Ghost
12. Trig +
13. Richard K +
14. Router +
15. Holty +
16. rip +
17. Geoff +
18. Freelander +
19.
20.
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Postby bobbrown » Mon 01.12.2008, 13:49
Gordon wrote:In line with Gasia's comments, I'll make up fitting kits for all the fans.
Hi Gordon,
When you say "I'm just trying to find grommets for a sensible price" how are you thinking of fitting these fans?
My idea would be to use a grommet as you suggest but with a center metal sleeve and a washer on the outside.
http://www.grommets.co.uk ????
If you need any help with any of this, like a center metal sleeve please feel free to email me direct and I can send you a picture of what I have in mind.
edit
fan fixing.jpg (14.59 KiB) Viewed 9207 times
something like that
Bob
Pacific Blue N/A
bobbrown
Postby Gordon » Mon 01.12.2008, 14:03
I'm only looking at replacing like for like, so no center sleave, and still using a plain washer, then a nylock nut. Just to keep the vibration down a little. Think I've got something lined up, just waiting for price.
Thanks,
Gordon,
2005 Vectra C....
Gordon
Postby Sy V » Mon 01.12.2008, 16:23
My memory is jaded (so I may be talking bollocks), but don't the bolts thread into captive nuts?
LEC Godfather
Postby bobbrown » Mon 01.12.2008, 17:14
Sy V you could well be half right as I think they are on captive bolts.
Like this, but may be with out the sleeve, I do not know as I have yet to take them off
fan fixing.jpg (22.91 KiB) Viewed 9190 times
Pacific Blue N/A
bobbrown
Postby Gordon » Mon 01.12.2008, 17:31
Mine are welded M5 studs, which looking at the parts manual, is correct.
4 along the lower support frame, and the other 4 along the upper crossmember.
The studs are only paritally threaded aswell - there were no sleeves on mine, and I have no reason to think the fans have ever been off...
2005 Vectra C....
Gordon
Postby bobbrown » Mon 01.12.2008, 17:34
That is what I was thinking was the case, welded studs/bolts
More bits to shear off !!!!
Pacific Blue N/A
bobbrown
Postby Gordon » Mon 01.12.2008, 17:35
bobbrown wrote:That is what I was thinking was the case, welded studs/bolts
Indeed - one of mine did :oops:
at least it was on the lower frame, so it's off the car for repair... :)
2005 Vectra C....
Gordon
Postby Gordon » Mon 01.12.2008, 23:17
It's probably worth a word of caution actually - These are only M5 studs (8mm hex nut), and don't take alot of effort to shear off.
If one of the bottom 4 on the radiator support frame shears, it's not the end of the world (drop the frame, drill & replace).
However - if you were to shear one of the upper ones off, I can imagine a world of pain..... take care out there.
Gordon
2005 Vectra C....
Gordon
Postby router » Mon 01.12.2008, 23:22
great,knowing my car it will be a pain in the arse and will take me 5 hours to change!
router
Postby GeoffSmith » Mon 01.12.2008, 23:26
First clean the threads with a small wire brush then apply loads of penetrating oil and take it easy.
Postby Gordon » Mon 01.12.2008, 23:40
router wrote:great,knowing my car it will be a pain in the arse and will take me 5 hours to change!
I would have thought 5 hours was pretty good even if nothing went wrong! (you have seen where they are haven't you?!) :lol:
Mine's been in bits 5 weeks now.. usual project creep...
I suspect my rad support frame is in pretty typical condition for a 1991 UK model:
1.Galsia +
2. Sy +
3. Ailwyn +
4. Ailwyn +
5. Dico +
6. BobBrown +
7. Stef
8. Dapinky +
9. Muley+
10.Woody
11. Ghost
12. Trig +
13. Richard K +
14. Router +
15. Holty +
16. rip +
17. Geoff +
18. Freelander +
19.
20.
2005 Vectra C....
Gordon
Postby dapinky » Tue 02.12.2008, 01:32
Gordon wrote:I suspect my rad support frame is in pretty typical condition for a 1991 UK model:
Nope - it's far better than mine was :shock:
Half an hour with a sandblaster and a bit of a squirt of etch primer and satin black hamerite had it good as new!
Postby Specky » Tue 02.12.2008, 14:34
mines worse too...
not much rust on mine thou...
But it's bent..... and one of the Y-brackets is really bent.... evidence of one of the front end crashes... :cry:
Postby Monty » Tue 02.12.2008, 15:37
Mine was not as bad as that one
Over a year ago
Cleaned & Painted
Postby Gordon » Tue 02.12.2008, 15:46
Ok, good news & not suprising news...
Final price for fans is £60 ( 2 fans, 8 grommets, 8 washers, 8 stainless nylock nuts) +P&P
As I said earlier, if anyone wants me to solder the correct plugs onto the leads, and heatshrink the joint, I'm quite happy to do that for a couple of quid extra, otherwise, they are bare tail ended.
Supplier only has 30 in stock (I suspect they were bluffing slightly) - lead time on next order is around 6 weeks - they're coming in from the far east somewhere.
P&P will probably be about £9 per pair - I've got to get some packing as the order will be in one crate apparently.
Assuming everyone is still in, please feel free to juggle your place in the list (down that is, unless you liase between each other) if you dont need them in any particular hurry.
Anyone nearby to tamworth (or coventry) is quite welcome to collect - I've never done this before, so I'm a bit vauge on how payment is best done - I'm quite happy with cheques, or direct credits. personally I hate paypal but if that's the prefered method then I do have an account.
Gordon
1.Galsia +
2. Sy +
3. Ailwyn +
4. Ailwyn +
5. Dico +
6. BobBrown +
7. Stef
8. Dapinky +
9. Muley+
10.Woody
11. Ghost
12. Trig +
13. Richard K +
14. Router +
15. Holty +
16. rip +
17. Geoff +
18. Freelander +
19.
20.
2005 Vectra C....
Gordon
Postby router » Tue 02.12.2008, 16:16
How soon will you get them, I am travelling down from Sheffield to Bristol a week on Saturday so I maybe able to collect and drop some off for others to collect.....
Neil
router
Postby Gordon » Tue 02.12.2008, 16:37
router wrote:How soon will you get them, I am travelling down from Sheffield to Bristol a week on Saturday so I maybe able to collect and drop some off for others to collect.....
Neil
This being "holiday season" an all, I'm away that weekend (13th/14th). I suspect anyway that by the time I've got the money together & placed the order, they probably wouldnt be with me quite that soon. When are you coming back :wink:
Gordon
2005 Vectra C....
Gordon
Postby dapinky » Tue 02.12.2008, 16:43
PM me your address for a cheque, or bank details for electronic transfer - whichever you prefer
Users browsing this forum: No registered users and 24 guests
