Replacement Fans (UK Turbo & NA)
Re: Replacement Fans (UK Turbo & NA)
Postby Gordon » Thu 11.12.2008, 18:07
The connector is made by Delphi, in thier Weatherpack range.
Not especially cheap, and at around $6 USD a connector, but if anyone can source them REALLY cheap, let me know...
Weatherpack 2pin connector
I've found some cheap (ish) in the USA, but I suspect shipping would spoil it...
Weatherpack on Ebay USA
Preferably in the UK :roll:
I do agree it would be neater...
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Postby muley » Thu 11.12.2008, 18:15
They have them here ...
http://www.vehicle-wiring-products.eu/V ... ectors.php
about halfway down the page
Usual disclaimers
Postby Gordon » Thu 11.12.2008, 19:00
1.Galsia + Paid
2. Sy + Paid
3. Chrisp + Paid
4. Geoff + Paid
5. Dico + Paid
6. markv + Paid
7. Freelander + Paid
8. Dapinky + Paid
9. Muley+ Paid
10.Woody
11. Ghost Paid
12. Trig + Paid
13. Richard K + Paid
14. Router + Paid
15. Holty +
16. rip +
17. Ailwyn +
18. Ailwyn +
19. Gazza +
20. BFG in the BRG +
21. BobBrown +
2005 Vectra C....
Gordon
Postby Gordon » Thu 11.12.2008, 19:26
A possible compromise option if anyone's interested, might be to just buy pins?
(5.69 KiB) Downloaded 16 times
Then pull the plug housing off your old fan, and reuse?
Best price so-far is £30 for 100xSeals and 100xPins
opinions...?
muley wrote:They have them here ...
Usual disclaimers
I'm pretty sure they are AMP Superseal connectors - very similar to the Delphi Weatherpack, but needless to say - not compatible :(
2005 Vectra C....
Gordon
Postby markv » Thu 11.12.2008, 22:18
Is it the Male or Female plug we would need?
Postby markv » Thu 11.12.2008, 22:51
I assume we only need one gender (Female?). I've found a source who will do 20 plugs of the same gender plus pins and seals for $40 (=£27) including priority email from the USA, which seems pretty reasonable to me.
The terminal pins & seals come in two gauges: 18-20 gauge or 14-16 gauge. Does anyone have any idea which ours are?
Postby Gordon » Thu 11.12.2008, 23:06
markv wrote:I assume we only need one gender (Female?). I've found a source who will do 20 plugs of the same gender plus pins and seals for $40 (=£27) including priority email from the USA, which seems pretty reasonable to me.
That's not bad - as for gender, it's a little wierd - It looks like a female housing, but it has pins...
This might help:
We need 18-20 gauge.
Having pulled one apart, it would make excellent economic sense to re-use the housing, and just buy pins - 100 with seals would be good (and a smaller packet to post...)
Gordon
2005 Vectra C....
Gordon
Postby markv » Thu 11.12.2008, 23:10
the vendor told me "Just so you know, the male housings use the female pins and the female housings use the male pins", so that looks spot on. Any idea what gauge the pins are?
Postby Gordon » Thu 11.12.2008, 23:13
Gordon wrote:We need 18-20 gauge.
Gordon
2005 Vectra C....
Gordon
Postby Gordon » Thu 11.12.2008, 23:44
I've got a quote of $48 USD for 100 pins & seals, or $28 USD for 50 pins & Seals... (including post to the UK)...
Gordon
2005 Vectra C....
Gordon
Postby markv » Fri 12.12.2008, 01:38
My quote's a little bit more - $54. Thought I'd post it in full as it looks like someone else on the forum may be asking as well, and Bill seems to be a very helpful guy:-
"I think there are two people asking us about these items. We have
another person form the US asking for the same connectors, in about
the same quantity. You may want to be sure that two people are not
buying the same things. the price of the pins and the seals is $0.20
each. If you want 100 pins and 100 seals, that would be $40 for the
parts plus $14 for Priority Mail shipping.
Thanks,
Bill
HiPoParts.com
Visit us at http://www.HiPoParts.com
Postby Gordon » Fri 12.12.2008, 09:06
I think Bill was getting most confused with both of us asking the same questions!!
We could of course order 100 pins and seals, so that they can all have the right pins on them, and say 10 new covers for those who don't want to DIY?
when the non-diy'rs have had thier old fans removed (complete with plugs), the plugs could be passed on to the next non diy'r?
we could of course go the whole hog, and just buy 50 plugs and 100 pins - it is quite possible that I'm scrimping around here, and in reality saving nothing?
(That said, I've already collected everyone's money, and I dont really want to go knocking for effectivly another £5 off everyone!)
buying the plugs individually is expensive though - jurys out....
2005 Vectra C....
Gordon
Postby ailwyn » Fri 12.12.2008, 09:40
Gordon,
I'm assuming that both connectors are fairly accessible on the car... is there an opportunity to look for something different to be used (that's cheaper and readily available) for example the connectors for the reversing switch on the gearbox?
Ailwyn
ailwyn
Postby Gordon » Fri 12.12.2008, 10:31
ailwyn wrote:Gordon,
Ailwyn
The connectors are pretty easy to get to - infact, once unplugged from the radiator, they pull up into the engine bay near the circulation pump, and would be really easy to change...
It is a fairly high current rated connection around 7A continuous load, and a pretty harsh enviroment which I guess explains the choice in connector; most of that style of waterproof connectors are a similar price - and of course putting the right plug on the fan means not having to modify the factory fitted plug on the loom...
Personally, I was quite happy to just re-use the plugs off my old fans, and solder/heatshrink them onto the new fans...
I think pins only, and re-use the old plug housings is a nice compromise (and neater), which if I had the pins to hand, I would do;
The question has come about I guess to allow the fans to be swapped without any electrical modifications, so again that would mean having to stick with the weatherpack plug...
2005 Vectra C....
Gordon
Postby bobbrown » Fri 12.12.2008, 10:33
wot like these
http://www.dun-bri.com/ShowDetails.asp?id=771
or these
Edit
Not sure if these are the same but would do the job at 20amp
http://www.polevolt.co.uk/
BTW remember stuff from the USA is subject to duty and then VAT on the lot
Pacific Blue N/A
bobbrown
Postby Gordon » Fri 12.12.2008, 11:04
bobbrown wrote:wot like these
I'm sure Superseal connectors would do the job, however, you would have to change both halves, as they are not compatible with Weatherpack connectors.
I may possibly have found a UK source of the weatherpack parts...
2005 Vectra C....
Gordon
Postby dapinky » Fri 12.12.2008, 11:55
As i only have one fan on the red one, I'll have to obtain/change the wiring anyway (The car side connector is there, but with a missing fan, that one isn't)
Postby Gordon » Fri 12.12.2008, 13:31
OK, in order to simplify all this, I've bought some plugs (I already have a suitable ratchet crimp tool).
These are the proper Delphi Weatherpack plug, and will fit the sockets on the existing loom.
The original price of £60 for a pair of fans stands as is, and the fans will be shipped with bare tails for you to do with what ever takes your fancy;
For an extra £6, I'll put the correct plugs on both fans (£3 per fan) so they become a straight swapout.
BTW, the fans have been ordered, I'm expecting delivery today.
Gordon
2005 Vectra C....
Gordon
Postby Sy V » Fri 12.12.2008, 13:59
Gordon wrote:...(no choc block or rubbish crimps)...
Aah, we know an electrical engineer whose good at these, don't we children?
LEC Godfather
Postby Sy V » Fri 12.12.2008, 14:06
Excellent work Gordon!
£6.00 for peace of mind is superb, but not worth getting the cheque book out for (IMHO of course).
How does a £7.50 PayPal payment sound?
Sy
LEC Godfather
Users browsing this forum: No registered users and 16 guests
