Here are a few photos from the NEC , sorry about the lighting we did as good as we could over the weekend with photos but it was packed to the brim and im sure several of you came along for a chat. CJ
bobbrown wrote:rickl wrote:hello everyones. how do i purchase this kit in america?
You can purchase the calipers in the USA and the discs should be available over there but will need modified to a 4 bolt pattern which is reasonably easy and can supply instructions(uses the original disc and a tool I can supply as a drilling jig).
The hardware should be easy to obtain over there.
The brackets I can supply from here
Wilwood Dynapro/Midlite parts list
1. Wilwood Dynapro/Midlite calipers
Option (A) 2 x 120-7328 Piston size1.50" 38.1 mm Disc thickness 1.00" – 25.4 mm
Option (B) 2 x 120-7377 Piston size1.50" 35.1 mm Disc thickness 1.00" – 25.4 mm
2. Subaru Impreza front discs
(A) 2 x 16” rim 294mm x 24mm re drilled to a 4 bolt pattern.
(B) 2 x 15” rim 275mm x 24mm re-machined to fit and re drilled to a 4 bolt pattern.
3. 2 x Caliper mounting bracket (adjust for dim size)
4. 2 x Stainless steel M10 x 1.0 banjo bolts (short)
5. 4 x M10 copper washers for above
6. 4 x 3/8” UNC x 2” cap screws min 10.9 (caliper to bracket)
7. 4 x 3/8” Schnorr Safety Washers
8. 4 x 1/2” Schnorr Safety Washers
9. 2 x M6 x 20 counter sunk keep screws
10. 2 x spigot rings
11. Disc drilling jig optional (needs original disc and idealy access to a pillar drill capable of drilling 1/2")
Note: Either size of caliper will work the 7377 maintains the closest to the original front to rear bias but if considering upgrading the rear then the 7328 is the one to go for.
The calipers can be changed to the Hi-spec product and the only parts that change are the brackets and the caliper to bracket cap screws (M10 x 50)
lotos wrote:
Uh oh - I'm not seeing these Wilwood calipers for sale online anywhere any longer... (They used to be on Jegs, Summit, and a handful of others, as well as ebay) Were they discontinued or replaced by new part numbers? Weird...
Bob - have you sent any kits to the US yet? Perhaps we could get a list together and you could ship over a few brackets / hardware kits at once to save on shipping cost? I know last time we chatted shipping was over $100 (although that was with more than brackets).
bobbrown wrote:I can get Hi-spec calipers for $206.00 (including our VAT)
bobbrown wrote:You may want to see what you need to pay for the other parts there like the discs which are from the following
Forester 02- F
Impreza 96-05 F
Legacy 94-03 F
Legacy Estate 99-03 F
Legacy Outback 99-03 F
ops! just checked my figures and took too much off the list price.
it should have read
"The Wilwood calipers I can get here for $175.00 no vat but I have to buy 4 calipers which if you then shipped then back to the US would probably equate to $760.00 or $190.00 each does seem a bit silly to me."
If I were to supply the kit less discs, pads and hoses then the cost with either Wilwood or Hi-spec (add $12.00 for Hi spec) calipers would be $645.00 delivered.
Discs would need to be sourced in the USA as they are the heavy part and therefore expensive to ship and I can supply a jig to redrill them to 4 stud.
