by Elanlover » Fri 23.01.2009, 14:25
DeeAitch wrote:My car came with S2 wheels and they still have the 19mm AF bolts - Geoff posted a nice spanner fix
to protect the paint from the spanner a while ago
Might that be the John Benk commemorative pink tape fix???
by Enright » Fri 23.01.2009, 22:10
Erm, I think all paint needed to be protected from THAT particular "spanner"!
He brought a new meaning to the term "solvent abuse"!
Neil
- Modificator
by lotos » Fri 23.01.2009, 22:20
nitroman wrote:Randy, if you wanna wait for the weekend I'll remove one bolt from each, then post a side-by-side photo along with measurements.
I have to wait a day or two?? Sheesh...
Thanks.
lotos
by nitroman » Sat 24.01.2009, 20:34
The S2 wheel bolt is up & to the left. These are each the factory supplied bolts. A S2 requires a 17mm socket, while the Federal requires a 19mm.
You could use a S2 bolt on a Federal wheel, but using a Federal bolt on a S2 wheel would leave you with that long bolt head protruding proud of the wheel surface; not a good look in my opinion.
- Attachments
- Wheel-Bolt-2.jpg (59.27 KiB) Viewed 17268 times
- Wheel-Bolt-1.JPG (46.09 KiB) Viewed 17274 times
nitroman
by lotos » Sat 24.01.2009, 21:37
nitroman wrote:The S2 wheel bolt is up & to the left.
Matt - I really appreciate your help here, I'm going to get the correct bolts. SJ's seems to have them in stock:
WHEEL BOLT (BBS Wheels) A100G6030F EACH 2.44. (Holy crap - £40 for the bolts?)Jackonicko wrote:The SE and Fed use a 19-mm HEX, whereas the S2 uses 17-mm.
The bolts are otherwise the same - thread (M12 x 1.5), length (23 or 25 mm i think, but I can't remember off hand!) and conical taper (60°).
The torque should be 80-88Nm / 59-65 lbs/ft
Thanks! Measuring Matt's picture, it looks like 23-24 mm in length.
I assume I don't need a special tire valve...
lotos on Sat 24.01.2009, 21:48, edited 5 times in total.
lotos
by dapinky » Sat 24.01.2009, 21:41
lotos wrote:Matt - I really appreciate your help here, I'm going to get the correct bolts.
Anyone know where they're available? I need about... 16 of them
Something like
these?
- LEC Administrator
by GeoffSmith » Sat 24.01.2009, 21:53
Elanlover wrote:Might that be the John Benk commemorative pink tape fix???
Got a better camera now!
- Kitty Fiddler
by GeoffSmith » Sat 24.01.2009, 21:56
dapinky wrote:lotos wrote:Matt - I really appreciate your help here, I'm going to get the correct bolts.
Something like
these?
Let me know if you want me to buy them and ship them with the rest of the stuff Randy.
- Kitty Fiddler
by lotos » Sat 24.01.2009, 22:14
Thanks - but it looks like I can find them locally for similar money.
Looks like any bolt that meets these specs will work (measuring Matt's S2 lug bolt):
17mm head
12 x 1.5
24 mm thread length
54 mm overall length
Can I assume that if the thread length is a little longer, no big deal (I'm talking like 5 mm more)? I've found some a little longer, some a little shorter. Which is preferable given that finding the exact specs above is unlikely?
lotos on Sun 25.01.2009, 19:26, edited 1 time in total.
lotos
by router » Sun 25.01.2009, 10:46
As for the center caps, on the S2 I thought the snapped in from the front side not from behind like the FED wheels. I just sold a set of S2 center caps and they did not look like they would go in from the rear
I can confirm this is the case, I have a spare set of new centre caps for the BBS wheels and they snap in from the face side of the wheel.
router
by algirdas » Sun 25.01.2009, 22:51
Dear Randy:
If you are in a bind, it is my recollection that a BMW lug bolt will work. I have a pile of them sitting on the work bench in the garage and, if you want to try them, please let me know and I'll bring a bag full to Tuesday's LOCO meeting.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
by bobbrown » Mon 26.01.2009, 01:27
lotos wrote:Thanks - but it looks like I can find them locally for similar money.
17mm head
12 x 1.5
24 mm thread length
They need to be 10.9 tensile strength or what ever it is over there grade 8 I think.
You will need to be a little carefull on length as there is limited room on the front before you hit the hub carrier with the bolts, rear not a problem and you do not want them short either.
I think the measurement is 15mm protruding from the wheel but will check.
Bob
Pacific Blue N/A
bobbrown
by GeoffSmith » Mon 26.01.2009, 01:59
bobbrown wrote:I think the measurement is 15mm protruding from the wheel but will check.
I've measured 19mm.
- Kitty Fiddler
by bobbrown » Mon 26.01.2009, 02:05
Geoff you could be correct at 19mm
Bob
Pacific Blue N/A
bobbrown
by bobbrown » Mon 26.01.2009, 18:25
The front hub flange is 13.5mm thick so anything over 15mm protruding from the wheel is not doing anything.
If you go to 25mm + protruding you will hit the hub carrier, so Geoff's 19mm is ok and in fact anything that is 15mm to 20mm would be fine.
Pacific Blue N/A
bobbrown
by lotos » Mon 26.01.2009, 22:43
lotos
by GeoffSmith » Mon 26.01.2009, 23:20
Randy,
Measuring my S2 bolt gives comparative figures of:
25mm thread length
52mm overall length.
These result in the 19mm protrusion I measured yesterday, which is only 1mm short of Bob's maximum of 20mm, so I would tend towards the 23mm/50mm ones.
Geoff
PS SJ order placed today - waiting for Steve to get back to me.
- Kitty Fiddler
by lotos » Tue 03.02.2009, 18:44
I've acquired some lug bolts, I'm hoping you all can tell me if they'll work.
Measurements:
Total length - 52mm
head length - 11mm
thread length - 24mm
thread end to beginning of cone - 27mm
The head is imprinted with: CFI 10.9
What do you think?
My phone won't take a good picture (and the wife has the digicam today).
- Attachments
- Bad pic of the lug bolt from my cell phone
- phone-lug.jpg (107.14 KiB) Viewed 17054 times
lotos
by lotos » Wed 04.02.2009, 02:06
A better pic
- Attachments
- Better pic
- lug.jpg (34.03 KiB) Viewed 17031 times
lotos
by tigerdog » Thu 05.02.2009, 19:04
You're turning this car from merely "new" to "stellar"! Great work - please keep up the posts.
Users browsing this forum: Google [Bot] and 3 guests
