MattDon wrote:how does one get access to the jackshaft nuts on the gearbox, same question goes for the nearside as i cant even see those nuts. do i need to remove the subframe?
Im also struggeling to get the exhaust off by myself, ive got the clips off and the front rubber mount off im just struggling to pull it apart.
Specky wrote:Simple to remove,
undo/crack hub nut done
jack up done
undo jack shaft bolts on gearbox i just cant workout where these or the circlips are
remove coil over
remove raft assy complete with wishbones and hub, leave caliper connected
slide out drive shaft assy
split shaft on work bench
Specky wrote:The left is harder, you have to pop that circlip... and it's a bugger..
MattDon wrote:bit of a blatant bump, apollogies but i need the question above answering before i can progress further. cheers.
