dapinky wrote:Not stupid at all....
....the only really stupid question is the one you don't ask in case you look stupid!
The air will be coming from the solid pipe through the wing, into the rubber 'dog-leg' shaped hose, and into the engine (from right to left in the picture)
max and andy wrote:If i wasn't doing anything with the information given that would be idiotic i happen to think it very important. Andy
max and andy wrote:I took the hose off the turbo and the blades moved free it looks in quite good nick going off the photos of others Ive seen. I replaced the small bore hose to the wastegate capsule and the hose coming from the bottom round the right of the engine to a i think sensor with a red and black wires with a glass top to look through. The hose had the MBC in it. And what a pig of a job that was Ive no skin left on my hands. I removed the big top hose there was air being sucked into the DOHC 16v part. The pipe coming out of the right wing i could feel air coming out when you drop the throttle. I think i could also hear something over run when you switch off. So i think the turbo is working. I tried to listen for any leeks but i couldn't here anything that sounded like a leek. Andy
Enright wrote:If it was a large leak somewhere (from something like a hose having popped off completely) then you need to trace the path of air from the turbo through the intercooler and into the intake plenum (the bit with "DOHC 16V" written on it).
You could undo the jubilee clip going into the throttle body, rev the engine and see if it blows air in your face. That would be a good next step.
max and andy wrote:Its blowing warm air when the throttle is dipped. Sorry it sucks air in at that end it blows from the wing.
max and andy wrote:Thanks guys i will have a go at blocking the actuation capsuel in the morning. Thats if my fingers are up to it. I cut them to ribbens putting the bottom hose on the capsuel. Two hoses in three hours and one was only 6cm long. It must be a record. I was thinking to change them all. Yes right. Not until it needs the engine out. Better not tempt fate. I seem to spend more time picking bolts and spanners up that i have dropped in the engine bay than i do work. Im going to tie them to a peice of string next time. Anyway back to work they wont pay me for being on this all night. Well they will but not for long. Cheers Andy.
max and andy wrote:
Well I'm back at it again (I can here the groans).
max and andy wrote:Well I'm back at it again (I can here the groans). I have plugged the hose coming off the bottom of the actuation capsule. All the other hoses connected. I took it for a short run when you put your foot down. The turbo gauge needle moves 5 or 6mm but i cant say i feel any boost. It is the hose coming off the capsule you wanted me to plug, and not the end the short bit of hose goes into? Andy
