wind deflector advice please
Re: wind deflector advice please
Postby BFG in the BRG » Wed 25.02.2009, 18:07
I like!
:beer:
Where did you get the cutting done?
Dimensions?
Not sure about using the M100 window winders though, since they are on a curve - but like the idea of "pressing a button"
Given me a few ideas
Alas soon to be Elan-less
BFG in the BRG
Postby BFG in the BRG » Sat 21.03.2009, 00:16
Just so you know, if anyone is interested, I've just started a group buy for the Classic Additions Wind blocker £125 delivered :banana:
http://forum.lotuselancentral.com/viewtopic.php?f=85&t=14530
BFG in the BRG
Re:
Postby texas2201 » Sat 21.03.2009, 21:43
Enright wrote:Couldn't find my old post with the pics, but at least I found the pics themselves, so here they are:
I have one of these which cost me £99 plus fitting and it will be for sale shortly as I am fitting some LGM rollhoops with built in wind deflecter
looking for £65 plus postage
Martin 07785 293305
Postby max and andy » Sun 22.03.2009, 00:41
I would be very interested.But going by your name Tex your in the US.The cost of shipping will probably put it past the price of new. Max & Andy
max and andy
Postby max and andy » Sun 22.03.2009, 04:02
Well thats me put right on making assumptions.I thought you cant possibly bump your car in Newbury .Bad luck by the way.And live in the US.If you decide to sell the wind brake we are interested.It is a classic additions model ?Max & Andy
max and andy
Postby texas2201 » Sun 22.03.2009, 09:47
Hi Max and Andy
No it is the MX5 derivative as per Enrights photos above - available next week if you want it
Martin 07785 293305
Postby tweetdriver63 » Wed 01.04.2009, 03:21
Just arrived. Ebay, $29.95 (sweet) from WindblokkerUSA, originally for the MX5.
Looks like the next project is ready to begin! :D
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby tweetdriver63 » Wed 08.04.2009, 04:56
I've installed the windblocker. Pictures are in my thread under major projects. One issue that has been raised before is that the top of this kind of windblocker ends up beint right in the middle of your view in the rear-view mirror. I have that problem too. I have come up with two solutions, not involving having the thing mounted on a track that allows it to be easily raised or lowered. The first is "live with it." It is annoying, and at certain distances in trail, it can completely block the view of a following vehicle. Of course, a look in the side mirror will show a clear view of a car that far back anyway. On the bright side, I noticed tonight, that the same thing that is annoying in the daylight, is a huge positive at night. Instead of not seeing a car behind me, I see it, but it's headlights don't shine in the mirror. The cars behind me can have their high-beams on, and I'm not affected at all by it. The second solution, which I'm now testing for a few days, is just to push the mirror up as high as its mounting will allow, changing the viewing angle so that the top of the windblocker is now almost out of view. I'm now looking over it when I look into the mirror. I'll let you know in a few days how that works out.
'91 Elan SE
tweetdriver63
Postby max and andy » Wed 08.04.2009, 08:27
Looks good and so cheep. We fitted the MX5 derivative at the weekend. I think because the side brackets are slightly longer then the one you have fitted and yours looks taller then ares anyway we don't seem to have the same rear view issues that your having. The only issue we had was that the brackets that fit to the car. The fixing holes would be better placed if they ran vertical instead of horizontal. The way owners are the off side wholes line up just on the bend of the back panel. Which doesn't give you a lot to fix to. If the second hole was under the first it wouldn't be an issue. We still prefer the push in and pull out aspect of the MX5 derivative. I have just noticed your is an MX5 derivative as well. Hows that they look different fittings unless yours is for a latter model. We have the one with the two prongs that push into two fixed brackets. Which are quick release. Max & Andy
max and andy
Postby nitroman » Fri 17.04.2009, 07:26
*LUCA* wrote:I chose a dark color kevlar for when I want more privacy safety, without that annoying feeling of getting shot!
windbullet deflector
nitroman
Postby JimF » Mon 04.05.2009, 12:49
tweetdriver63 wrote:I've installed the windblocker. Pictures are in my thread under major projects. One issue that has been raised before is that the top of this kind of windblocker ends up beint right in the middle of your view in the rear-view mirror. I have that problem too. I have come up with two solutions, not involving having the thing mounted on a track that allows it to be easily raised or lowered. The first is "live with it." It is annoying, and at certain distances in trail, it can completely block the view of a following vehicle. Of course, a look in the side mirror will show a clear view of a car that far back anyway. On the bright side, I noticed tonight, that the same thing that is annoying in the daylight, is a huge positive at night. Instead of not seeing a car behind me, I see it, but it's headlights don't shine in the mirror. The cars behind me can have their high-beams on, and I'm not affected at all by it. The second solution, which I'm now testing for a few days, is just to push the mirror up as high as its mounting will allow, changing the viewing angle so that the top of the windblocker is now almost out of view. I'm now looking over it when I look into the mirror. I'll let you know in a few days how that works out.
I have a Classic Additions one fitted on the S2. Being tall, the top on that one was also right in the middle of the rear view mirror. I took the supplied brackets and drilled another 6mm hole at the far end, turned them upside down and refitted. It lifted the screen to clear the mirror view, still has adequate clearance for hood operation and doesn't appear to alter the stability, function or appearance.
Azure Blue S2
JimF
Postby hilda » Fri 08.05.2009, 14:37
I've just bought a wind deflector on line from www. classicadditions.co.uk made specifically for the M100.
1990 white elan
hilda
Postby nitroman » Sun 27.12.2009, 04:20
http://blogs.automobilemag.com/6599000/ ... index.html
Something new MB is installing on all 2010 E-class convertibles.
nitroman
Postby stonefish » Sun 27.12.2009, 12:16
hi mick,
dont know if this helps but i built a lotus 7 kit car and used plexiglass to make the side windows...it didnt scratch too much and was flexible so it didnt shatter in the cold.
hope this helps
jeff
stonefish
Postby VagueShot » Sun 27.12.2009, 15:16
Thanks for the pointer to classic additions. Just bought a half cover to stop my cat sleeping on the hood.
James Miller
http://anonw.wordpress.com/tag/lotus-elan/ - Ramblings of an anonymous widower and sometimes his ever-faithful Lotus Elan.
VagueShot
