Alternate willwood brake upgrade with dust seals
Re: Alternate willwood brake upgrade with dust seals
Postby bobbrown » Wed 08.04.2009, 08:48
I do not have a Wilwood caliper here for a direct comparison but there is very little to choose between them.
The Wilwood is possibly a better caliper in as much as it is a two piece forged caliper as apposed to the Hi-Spec which 3 piece machined from an aluminium billet.
The Hi-Spec caliper has been used here on the Elan for a number of years now with out any major problems and no doubt the Wilwood one has been used successfully on a large number of vehicles in the US.
Hi-spec does allow for different colours at no extra cost but I think Wilwoods are only available in black or red the red costing more.
The Hi Spec caliper uses a slightly larger pad than the Wilwood.
Wilwood on the left, Hi- Spec on the right.
The Wilwood pads are available in a various materials and you can also get an EBC pad (EBC-DP2039 or EBC-DP3039 green and red stuff).
Hi-Spec uses a pad from a Volvo 240 series (EBC-DP143, EBC-DP2143, EBC-DP3143, EBC-DP4143) and they are available from places like Summit from about $70 so supply of those is not a problem.
Discs should not be a problem just need drilling and the holes do not have to be that accurate as they are 12.8mm diameter (1/2" is close at 12.7mm) for a 12 mm bolt and the load is not carried by the bolt it's self more by the clamp load wheel to hub.
Bob
Pacific Blue N/A
bobbrown
Postby lotos » Wed 08.04.2009, 16:42
Thanks for the info! Looks like after buying rotors and pads, we're talking about ~ $750, plus $100 for brake lines. If my memory serves, you said that the Hi-Spec calipers use a standard connection, the Wilwoods require re-tapping, right? My overall plan is to powdercoat the new calipers (and the OEM rear calipers) yellow before installation, so the color choices don't matter to me.
Arrgggg. Don't know which to choose :)
lotos
Postby bobbrown » Wed 08.04.2009, 19:17
lotos wrote:Thanks for the info! Looks like after buying rotors and pads, we're talking about ~ $750, plus $100 for brake lines. If my memory serves, you said that the Hi-Spec calipers use a standard connection, the Wilwoods require re-tapping, right? My overall plan is to powdercoat the new calipers (and the OEM rear calipers) yellow before installation, so the color choices don't matter to me.
Wilwood calipers have a 1/8 NPT fluid connection which can either be retapped M10 or you would need a hose with the same fitting as the original Wilwood upgrades.
If you were going to paint the calipers then why not go for the Hi-spec Economy calipers which would be about $315.00 including our VAT the pair same caliper just no fancy finish saving about $100.00.
Bob
Pacific Blue N/A
bobbrown
Postby lotos » Wed 08.04.2009, 19:55
That sounds like a great option for me. The website looks like the only difference is an embossed vs engraved logo, I think the embossed logo will look better after powdercoating anyhow.
Is it a lot of work to prep a caliper for powder, and then reassemble? Uh oh... Opening a can of worms here.
lotos
Postby bobbrown » Wed 08.04.2009, 20:32
Not sure that powder coating is the way to go but there are certainly some good caliper paints available all be it you will need to use an etch primer first to key the paint.
To split the Hi spec calipers is relatively easy just 6 cap screws and they are in two halves, you would need then to mask off the areas not to be painted.
Finish with a few coats of caliper lacquer and they should look good.
Aerosol cans might prove a low cost way to achieve this and could be tested on a scrap of aluminium to see what results are like.
Bob
Pacific Blue N/A
bobbrown
Postby lotos » Wed 08.04.2009, 20:44
Okay forget I said anything about powdercoating the calipers :)
We'll be in touch, bob. Thanks again for the info.
lotos
Postby Doug » Thu 09.04.2009, 01:14
Randy, when I got my Wilwood calipers, the brake place did a powdercoat in yellow for me = no fuss and no need for me to worry about disassembling, etc
I don't recall the name of the place, but I did arrange for Monty and others to get parts from them too here in the US, so perhaps they have the records about -- my records are with Ekapol.
Postby ratman » Tue 21.04.2009, 17:17
ciao,
I would update my front brakes and calipers of my S2 (16" OEM rims) and I would know the present quotation of a willwood or hi-spec system.
I have std system and goodridge steel brake lines. to be honest, I would use the cheaper of the two (16" rims) options.
what is now the one that you could advice?
thanks, F.
Lotus Elan S2 n°538
ratman
Postby bobbrown » Tue 21.04.2009, 18:11
ratman you have a pm
Pacific Blue N/A
bobbrown
Postby woody » Wed 22.04.2009, 09:45
Just how bad is the dust problem on the Wilwood set-up using the original dynalite caliers without the dust seals.
What is peoples experience with this set up ?
Woody
woody
Postby vi11ain » Wed 22.04.2009, 17:35
I don't think the problem is really "dust" - it's more along the line of corrosion on the pistons, leading to them sticking.
Similar in a way to the problems with the original brakes and corrosion of the sliders.
Ben
...of the plot
vi11ain
Postby bobbrown » Wed 22.04.2009, 21:15
Not sure about the corrosion as the pistons are stainless steel but the dirt build up will present a problem when faced with the simple task of replacing the pads as the pistons will need to be clean before they are pushed back into the caliper.
With dust seals this is not a problem.
Bob
Pacific Blue N/A
bobbrown
Postby ratman » Fri 24.04.2009, 11:10
Ciao,
I have one more question:
is the pedal free movement going to be shoertened with the Hi-spec system?
Lotus Elan S2 n°538
ratman
Postby bobbrown » Fri 24.04.2009, 12:49
Pedal travel is dependant on the amount of fluid that had to be moved and as far as I am aware there was only one upgrade that suffered this problem and it was down to large pistoned calipers being fitted by mistake 44.5mm instead of 35.1mm due to a mix up in part numbers 6816 instead of 6806.
Although this does not seem a lot in terms of area it is around 46% over the stock caliper, the 35.1mm caliper is slightly less than standard but running on a bigger disc and the Hi-spec's are only 10% this is calipers piston areas.
Bob
Pacific Blue N/A
bobbrown
Postby ratman » Fri 24.04.2009, 13:07
Ciao,
thanks for your reply.
As far as I am suffering a too long free pedal travel in spite of steel brake lines, I was wondering if the kit would improve the issue or not. do you think that any action should be made before the upgrade?
Lotus Elan S2 n°538
ratman
Postby bobbrown » Fri 24.04.2009, 13:12
If you have long pedal travel on a standard system then some thing is amiss and the chances are it is stuck/sticky sliding pins. If you intend to upgrade then this problem goes out of the window as the upgrades do away with sliding pins
4 pot front 2 pot rear
If you only upgrade the front then the rears will need to be checked to ensure they are working correctly.
Bob
Pacific Blue N/A
bobbrown
Postby ratman » Fri 24.04.2009, 16:21
sticking pistons will create an issue similar to knock-off issue? If my calipers have this problem, should I notice a reduction of free pedal travel when I press twice the brake while stopping? :roll:
Lotus Elan S2 n°538
ratman
Postby bobbrown » Fri 24.04.2009, 16:39
I doubt it is a sticking piston issue but more likely a sliding pin problem.
The calipers fitted as standard to the Elan are single piston and as such have pins that the out board half of the caliper slides on. If these are stuck then the chance are you will be required to press harder and have more pedal travel than if they were free.
Knock back of pads is a different issue and is usually due to a warped disc or the like.
The results of stuck pins is really rubbish brakes not that the standard brakes are that good to begin with lets just say they are adequate for the road.
Bob
Pacific Blue N/A
bobbrown
Postby ratman » Fri 24.04.2009, 16:59
Ciao,
thanks for your help! I suppose that it is necessary to disassemble completely the caliper for the sliding pins check and it shouldn't be possible to check them in another easier way...
Lotus Elan S2 n°538
ratman
Postby ab2cv » Fri 24.04.2009, 18:13
ratman wrote:Ciao,
To check sliding pin operation, all you need to do is remove the pads. The caliper should be able to slide in and out just by moving it with your hand. If it doesn't move at all or takes considerable effort then your sliding pins need greased/replaced (along with the seals.
Alan
Yellow Esprit GT3
ab2cv
