The problem is as per title - Angie came home from work the other day, parked the car (facing downhill) and it stalled. It would not re-start for a while, then it did, but died again after about 5 seconds.
I went out to it a bit later and it fired up first time, idled for a while, so i drove off - 50 yds later, stalled again & failed to restart.
Got it home after a couple of hours of leaving it, but it stalled again!!!!
Same again today......
.....here's what it does, and what I've done....
When it runs, it seems fine, so I've ruled out a major mechanical failure.
That leaves fuel and sparks...
Spark plugs are fine (but dry), and i get a spark when conected in free air & cranking engine (so I was thinking petrol here).
The pump seems okay as i can hear it running for the usual couple of seconds when i turn on ignition, and it still runs when the engine dies (so I'm assuming the relay is okay).
I connected a spare piece of fuel pipe to the tank outlet, and when operating the ignition, it put about a cup full of fuel into a bucket before turning off.
The fuel seems okay (ie, it's petrol, not diesel or water!).
Put it all back together, and no change
It definately feels like no fuel is getting to the engine, but when it runs it runs fine and suddenly dies without a missfire (so i assume all injectors are working, otherwise it would only be on 2 cylinders).
Where do i go next??????? Fuel rail? pressure regulator? anywhere else?
