Head Light Motor Rebuilding
Re: Head Light Motor Rebuilding
Postby rip » Tue 24.03.2009, 09:05
Paul.P wrote:
GeoffSmith wrote:Thought I was seeing things: Gary, posting on a technical thread? :lol:
Ah yes Geoff, but it wasn't a very technical post, was it !
Postby lotos » Sun 29.03.2009, 02:28
When removing the wheel well plastic - does that just pop off? I've never done that sort of thing.
lotos
Postby GeoffSmith » Sun 29.03.2009, 10:34
There are a few retaining screws and bolts to remove. In the UK, these are a real bugger to remove and some will require a Dremel (which is why I changed mine to deeaitch's stainless) but you might find them a lot easier in your climate.
Postby lotos » Sun 29.03.2009, 15:12
For a minute I thought you meant you switched the wheel well plastic over to stainless steel. :beer:
lotos
Postby nitroman » Sun 29.03.2009, 20:30
lotos wrote:For a minute I thought you meant you switched the wheel well plastic over to stainless steel. :beer:
Have some 6mm well nuts on hand. http://www.desmoparts.com/ducati/wellnut/wellnut.htm
nitroman
Postby cyc0140 » Mon 20.04.2009, 09:56
Sorry guys, this thread is confusing for me. I saw "rip" and "gary" both posting that they have the headlamp rebuild kit. Can't seem to jump in the thread to communicate with them. I need a set to repair my RHS headlamp motor. The gear has given way. I live in Singapore so do quote me a price if you intend to release the repair kit. Thanks !
cyc0140
Postby lotos » Mon 20.04.2009, 20:37
http://www.rodneydickman.com/n21.html
Includes all the parts (except the gear itself, which apparently isn't ever the issue)
lotos
Postby nitroman » Tue 21.04.2009, 23:31
cyc0140 wrote:Sorry guys, this thread is confusing for me. I saw "rip" and "gary" both posting that they have the headlamp rebuild kit. Can't seem to jump in the thread to communicate with them. I need a set to repair my RHS headlamp motor. The gear has given way. I live in Singapore so do quote me a price if you intend to release the repair kit. Thanks !
http://www.top-downsolutions.com/produc ... d0c4494538
nitroman
Postby lotos » Wed 22.04.2009, 20:37
lotos
Postby cyc0140 » Thu 23.04.2009, 16:19
Thank you all for your advice. Spoke to Rodney and he will supply me the parts needed. He is a great guy too : )
cyc0140
Postby lotos » Thu 23.04.2009, 18:54
I agree - amazing service for a $5 product!
lotos
Postby frog » Sun 26.04.2009, 00:15
GeoffSmith wrote:There are a few retaining screws and bolts to remove. In the UK, these are a real bugger to remove and some will require a Dremel (which is why I changed mine to deeaitch's stainless) but you might find them a lot easier in your climate.
Glad you said that! - I'm stuck on getting the screw undone under the car (behind the wheel). Can you recommend how you would go about removing this and then having a way to secure the cover afterward?
frog
Postby GeoffSmith » Mon 27.04.2009, 16:31
I think I cut a slot in the head and got a big screwdriver on it - I wasn't too worried about damaging it though. Easy enough to source a replacement though.
Postby frog » Mon 04.05.2009, 01:04
Thanks - I'll give it a go.
frog
Postby Bolsom » Fri 05.06.2009, 18:41
I rebuilt my offside headlamp lift motor this afternoon. The 3 bearing thingies had turned to brown sugar crystals. The Nitroman advice to get the 6 mm well nuts paid
off, I needed 2 so thanks to him. The only problem I had was not being careful enough when retracting the motor brushes, one spring made an escape bid. I was very lucky to
find something so small. I found that using fishing line to retain them in place worked very well and once the motor is back but not tightened it pulls out very easily.
I used a little silicon grease on all the moving parts and on the holding bolts for the wheelarch liner. All the advice found in these threads was most appreciated.
Colin
Bolsom
Postby tweetdriver63 » Wed 17.06.2009, 06:19
Well, last year when my pax side light was acting up, I ordered a kit for it. Trouble is, I'm lazy. I saw a pax side rebuilt motor on ebay and bought it for about $40. Swapping out motors is really easy.
Now I'm having the same problem with my driver's side. Again, I was lazy and bought another rebuilt motor on ebay. As it turns out, a Firebird motor is the same motor, but the mountings are different, so I can't use it. I explained the problem to the seller and he made me an offer. I am sending him back the Firebird motor, and sending my old pax side motor with it. In exchange for the Firebird motor, he is going to rebuild my old pax side motor and reverse it so it will go on the driver's side. That way I don't have to live without one for any amount of time.
I didn't know that was possible, but apparently it is. That's really why I posted this. I don't know the actual process, but if you need a replacement, and can only find one for the wrong side, you can change which side it goes on. Just an interesting bit of info.
Also, I will have a left side motor (in need of rebuilding) and rebuild kit available if anybody needs it.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
