lotos wrote:1. Elanlover
2. superbad
3. lotos
4. cliffyg
Criminy that's a lot of scratch.
superbad wrote:What do you have right now exactly? Is there a sample or anything can be measured to make a set of drawings? I can create the drawings and get a couple dozen quotes on mfg.com, but I don't have an Elise wheel to measure, and I'd have to take my car apart to get the other dimensions (possible, but inconvenient as I drive it almost every day).
You'd be amazed at the disparity in machining quotes you get normally- when I put even a simple machined part out for quote, there's usually at least a factor of 10 difference between the high and low bid. That doesn't mean we could get these for $20- I think that $200 price is probably in the middle somewhere.
Elanlover wrote:Actually, I have nothing other than the picture posted here and kniowledge of what few differences needed to accomodate the Elise wheel. I'm not sure the guy I spoke with who did the original runs has drawings either. What I could do though is go to him and ask him for the drawings if he has them and thinks he won't have enough for a run. He might be kind enough to give me a copy if he has them. I'll e-mail him today.
lotos wrote:Now about converting to tilt-wheel.....
Elanlover wrote:On a related topic, I have the old steering wheel out for some work and got the speedo and fascia mask back in place. So, I held the Elise wheel up to get a sense of the view of the instruments. I'm 5'10" and i have lowered my seats about halfway from stock to the bare floor. The top of the speedo if cut off so you can't see the numbers at the top. Something like 100kmph (60mph) - 160kmph (100mph) are either partially or totally obscured. Also, on the tach, the numerals 1 and 2 are obscured and the fuel gauge is obscured from Full to about half empty. Now, If I lowered the seat further I think I could see most of the speedo. But, I don't think the sides will be more visible.
Elanlover wrote:lotos wrote:Now about converting to tilt-wheel.....
Don't think that'll happen although I did see a "possible" way to adjust the position of the wheel slightly. That's another thread though
nitroman wrote:Elanlover wrote:On a related topic, I have the old steering wheel out for some work and got the speedo and fascia mask back in place. So, I held the Elise wheel up to get a sense of the view of the instruments. I'm 5'10" and i have lowered my seats about halfway from stock to the bare floor. The top of the speedo if cut off so you can't see the numbers at the top. Something like 100kmph (60mph) - 160kmph (100mph) are either partially or totally obscured. Also, on the tach, the numerals 1 and 2 are obscured and the fuel gauge is obscured from Full to about half empty. Now, If I lowered the seat further I think I could see most of the speedo. But, I don't think the sides will be more visible.
What are the rim dimensions (OD & ID of the rim) of the Elise wheel VS the Elan wheel?
