Elanlover wrote:Nige wrote:The rear deck seal is fixed to the body not the deck, so seals are not required (unless your seal is shot. If so they were in the parts sale, not sure if they still are).
Of course DUH!Don't know what i was thinking.
Nige wrote:Oh go on Chris, you know it makes sense.
Exbury wrote:Paul,
What I meant is - if the list reaches 10 is that the cut off point i.e. one batch then that is it? I am interested but I would prefer to sort out something over June first. Or is it when the list reaches 10 then the first deposits can be taken, but any orders will be taken to the end of July. That way, Simon can get production underway but orders may still be coming in. Obviously this is down to Simon, i know he is doing this as a big favour and we are all appreciative, its just I really do want this but if it looks like I emigrate soon then this may be unnecessary if I could not take the car with me. If I knew there was a finally cut-off date and not cut-off volume point that would be great for me.
Also, I assume that the hoops are the lighter steel varient (is it chro-moly?). Also is there any 'testing' of the hoops, and I appreciate that this is low volume so I mean testing in terms of CAD/engineering estimates or has anyone say in motorsport actually flipped theer elan with a cage fitted and the crash recorded. While I fully appreciate its probably a buy at your own risk and there will be the usual disclaimers and that anything is going to be better than the current collapsable seatsI was just wondering. However with Simon's attention to detail he has probably way over-engineered it so it should be more than adequete, I am actually more concerned about the elan structural strength at the points of mounting.
Kuching wrote:By necessity therefore, it is not a quick, easy job to fit it. Several holes must be cut in the interior areas of the G/F tub, and some of the interior trim components need to be cut to clear tubes
Doug wrote:lotos wrote:Any guess as to what shipping to USA would run?
who cares, go for it Randy!
Elanlover wrote:Depends on what you're buying. Are you looking at the complete package with hoops, farrings and deck? If so I'd be willing to bet its going to cost between $125 and $200. That's just a semi educated guess based on the size and weight of the items. I think LGM's hoops I bought cost something like $80 to ship from California to Canada. This is more gear, a bigger package and further to travel.
lotos wrote:I'm nervous - I could see it creeping into $300-600 shipping cost. International shipping is pricey these days!
There could be a problem with your order due to the volumetric weight.
This will not affect the order process but we suggest that you contact
The Transglobal Express
woody wrote:If you would like to join this run, and are serious about proceeding, please add your name to the following list
1. PaulWatkins - Roll hoops + Fitting
2. markv - Roll hoops + Fitting
3. G UK - The Works + Fitting
4. Richard K - The Works + Instruction "Video"
5. mvf906 - Roll hoops + Fitting
6. enndee - Roll hoops + fitting
7.Woody - Roll hoops + fitting
8.Exbury - Roll hoops + probable fitting
9.
10.
Woody
