Isle of Man 2010
Re: Isle of Man 10th to 13th July 2009
Postby dapinky » Mon 06.07.2009, 13:39
Okay, then - It looks like brekkie at Stafford for the Southern lot!
Is the 0900 hours an arrival time or a departure time???????
Postby DaveT » Mon 06.07.2009, 18:16
Both- so eat up quick.
The earlier you are the more you get to eat. If we have traffic probs the breakfast is mobile, that way we can deal with events and make sure we catch the ferry.
THE PIMPERNEL MOD
Don't get mad- get even!!
Good days are Elan days
DaveT
Postby DaveT » Mon 06.07.2009, 18:21
8)
First one there gets 7 breakies and 7 coffees.
" I'm so excited!!!!!!!!"
" And I just cant hide it"
D
No beans on mine
and no gluten on Maxines
THE PIMPERNEL MOD
DaveT
Postby inkitin » Mon 06.07.2009, 18:39
So, if us Northerners get to Asda Runcorn at around about 09:30 then we should have enough time for a leisurely coffee before you guys arrive?
91 SE Calypso Red
inkitin
Postby dapinky » Mon 06.07.2009, 19:40
Could i be so bold as to suggest an attempt to arrive at Stafford at 0830, to leave at about 0900....... (so leaving W-s-M at 0630).....
this should get us to Asda at 0947 (call it leaving at 1000 to allow for fuel top-up).....
... That'll get us to the ferry at 1030.....
These timings are all based on Microsoft Autoroute, so allow for 60mph on Motorways....
....as such, with the rush hour traffic round Gods own County, and no breakdowns - all should be well for a coffee and cereals at the survices (but it'll probably be a large-black-with-sugar-in-a-paper-cup-to-go).
Still, I'm sure Paul will get out of his unpacking the house move soon and give me the accurate times!
Postby m400kay » Mon 06.07.2009, 23:30
okay runcorn it is, will leave early so can cruise down its about 250 ish miles for us we will take breakie at penrith so will be looking for fuel and coffee at runcorn, any plans for days on i.o.m. not tracking but looking for some fast road runs, have fitted yokohama's all round and car seems better but pilots were cracked and split except for one which am keeping as spare, unless anyone searching for one its as good as new, any one running yokos has any feed back.
red s1 elise
m400kay
Postby dapinky » Tue 07.07.2009, 16:05
m400kay wrote:any one running yokos has any feed back.
It all depends on the tyre you have.....
...I've got Yokohama 008R's on the front of the blue car - not brilliant on a wet track, but great on a dry one - and never a problem on a road (yet!).
They're an older design/pattern, but were the track tyre of choice in their day for many cars (and i don't remember ever seeing a mini without them).
IIRC Monty tried some of the newer ones, and hasn't had any problems. (539's????)
Postby DaveT » Tue 07.07.2009, 18:05
8)
I've just rebooted with some Michelin MMX 2,s
Just scrubbed them up yesterday on the way to GST. Seem to be really good in wet. At 30 mph they seem absolutely fine- my normal speed!!!!
THE PIMPERNEL MOD
DaveT
Postby Dave Eds » Tue 07.07.2009, 22:10
Toyo Proxy R888. One on each corner. :shock:
Postby chris.t » Tue 07.07.2009, 22:23
Dave Eds wrote:Toyo Proxy R888. One on each corner. :shock:
v.good but be careful in the wet :poke:
Postby Dave Eds » Tue 07.07.2009, 22:42
there won't be any wet - we used it all up last time :-D
Postby Specky » Tue 07.07.2009, 23:26
And Chris makes a good Mechanic to look after those tyre pressures... :wink:
One thing I would take is a little bit hydraulic fluid for your power steering, Mine started to come out through the breather. Hitting large puddles and aquaplaning on a very wet track at 90-100 tends to give your arms a good work out....
Which compound of 888 did you go for? I've got the mediums on...
Saying all the past few days of 30 degrees heat the grip has been something else, I can now see why Monty and a like changed their seats...
I hope you get crackin weather...
Postby m400kay » Wed 08.07.2009, 06:39
yoko s306 s i have the yoko lotus lts 008 s on elise so do not know if very different tread patterns look similar got these for 80 quid a corner so with iom and everything else went for them to save money seem ok but not relly done much more than a few tight b roads at reasonble speed but give more cofidence than cracking possibly hard and perisning pilots.
red s1 elise
m400kay
Postby Monty » Wed 08.07.2009, 12:08
Well i`m off to ireland tomorrow (not in the car thou) so have a good trip over the weekend :rally: :smt023
Postby G UK » Wed 08.07.2009, 14:19
OK, I'm annoyed.
Dogcamsport has let me down and I'm no longer going to have a camera this weekend now. Somehow they managed to not realise that their website was stating that shipping would start fom the begining of July when in actual fact they are not even recieving the units until the 14th!! Yes thats right, the day after I get back :evil:
Just checked the car over as shes not been run for a few days and topped up the liquids, tyres (Eagle F1's) all-round have plenty of life in them so I have no worries there but the front brake pads, although still with plenty of normal life in them, are looking a bit thin. I think I'll take some spares with me just in case!!
Now just to give her a good clean!
https://gridcoin.ddns.net
G UK
Postby tte200 » Wed 08.07.2009, 16:58
Hi all
Have took part in the group buy for a OEM Geraknob which Paul W has for me to collect. Would like to meet up with you all at ASDA Runcorn 930-1000 if I have the time correct say hello/meet a few owners collect gear knob and follow you through to the ferry terminal before you all depart for IOM and I return home.
91 SE Turbo
tte200
Postby DaveT » Wed 08.07.2009, 17:32
tte200 wrote:Hi all
Geraknob
Sounds like something a scouse would do.
THE PIMPERNEL MOD
DaveT
Postby tte200 » Wed 08.07.2009, 17:42
DaveT wrote:
tte200 wrote:Hi all
Geraknob
ok made a good first impression with that!!!!
91 SE Turbo
tte200
Postby inkitin » Wed 08.07.2009, 18:02
tte200 wrote:follow you through to the ferry terminal before you all depart for IOM and I return home.
Excellent !
Anybody else coming to wave us off? :-D
91 SE Calypso Red
inkitin
Postby dapinky » Wed 08.07.2009, 18:39
Hi Terry,
I'm not sure if Paul has unpacked his 'puter yet (he moved house this week) but I'll remind him when i give him a bell tommorrow to sort out times from Somerset!
The Runcorn timings sound good to me.
Return to Events - U.K.
