by Coupeboy » Tue 18.08.2009, 09:32
I have an alarm/remote system but the remote only works the passenger door lock and I have to use the key for the drivers door. I can understand the logic of this as the S1's only came with keys from the factory. Assuming that LHD cars have the same logic would this mean that it is possible to make the drivers door lock on a RHD car remotely controlled as well? Just a simple yes will suffice and if you happen to know where the module is to splice into, even better - don't know why the alarm fitter only managed the passenger door. Scoured this forum for answers but no luck, hence the question.
1992 Elan Pacific Blue SE
2007 325se Coupe
Coupeboy
by texas2201 » Tue 18.08.2009, 12:08
Mine is an 1990 S1 with alarm fitted by the factory and it opens both doors - you can download the manuals inc the electrical one on the forum
Martin
"brakes are no good - they just slow you down" Fangio
by esprit888 » Tue 18.08.2009, 17:46
Coupeboy wrote:I have an alarm/remote system but the remote only works the passenger door lock and I have to use the key for the drivers door. I can understand the logic of this as the S1's only came with keys from the factory. Assuming that LHD cars have the same logic would this mean that it is possible to make the drivers door lock on a RHD car remotely controlled as well? Just a simple yes will suffice and if you happen to know where the module is to splice into, even better - don't know why the alarm fitter only managed the passenger door. Scoured this forum for answers but no luck, hence the question.
I just had this done, go here:
http://forum.lotuselancentral.com/viewtopic.php?f=35&t=15479&p=206935#p206935
esprit888
Return to Doors and Windows
