by Jackonicko » Wed 26.08.2009, 11:04
I'm with Lotos. An aluminium door pull would be great, but it should be closer to the shape of the original, in my view. The hard edges (the angular grooves at the leading and trailing edge) don't suit the car, nor do they marry with the rest of the door trim.
Pointless criticism?
Perhaps.
But a smoother, more flowing shape and I'd have been up for these.
Jackonicko
by lotusgirlmarie » Wed 26.08.2009, 16:12
I concur. A satin or brushed finish would suit me best as well + it won't get as hot on the surface.
lotusgirlmarie
- Goddess
by F1 LOTUS » Wed 26.08.2009, 20:53
Satin-finish is easy - Scotchbrite!
Getting rid of the groove is also easy and would speed-up machining time a tad.
So long as we can have around 15 people agree on one design we can go forward with the project.
Keep the feedback coming
What's the consensus on shape - as shown with stepped surface, without, or same as stock?
F1 LOTUS
by Elanlover » Wed 26.08.2009, 21:11
I'm happy in the groove or not
The shape looks to be a bit more forward that the stock handle. Not a bad thing as on the stock pull there's a grey plastic gap that's visible between the edge of the CF escutcheon and where the leather insert ends. I wonder though what it would look like reveresed? With the pull looping backwards
by Jackonicko » Thu 27.08.2009, 22:28
1) Jackonicko - same as stock, no groove/ridge, satin/brushed - would buy, definitely. Wouldn't buy otherwise.
Jackonicko
by Elanlover » Fri 28.08.2009, 01:51
I'm happy without the groove as I've said above BUT I'm more happy if its NOT the stock shape. Brian will need to chime in here but it looks to me as though the shape is slightly more forward in his design with the curve slightly higher up towards the top of the pull. To me this is a better design that will allow your hand to fit into the pull easier and probably more comfortably. Its a small change (unless I'm seeing it incorrectly) that I think is an improvement.
by TimHays » Fri 16.10.2009, 23:31
You can put me down for a set of these.
Also, where do I get a set of those other inserts?
-Tim
TimHays
- Welcome to LEC - please introduce yourself
by theelanman » Fri 16.10.2009, 23:35
by F1 LOTUS » Sun 18.10.2009, 07:50
1. F1 LOTUS
2. superbad
3. Elanlover
4. rip
5. theelanman
6. esprit888
7. Mikeydude
8. Nige
9. TimHays
F1 LOTUS
by Candles » Tue 01.12.2009, 14:13
1. F1 LOTUS
2. superbad
3. Elanlover
4. rip
5. theelanman
6. esprit888
7. Mikeydude
8. Nige
9. TimHays
10. Candles (not really fussed either way, but if pressed, I prefer the groove)
Are the carbon escutcheons still available? I drove over one of mine
Candles
by theelanman » Tue 01.12.2009, 14:20
by superbad » Tue 23.02.2010, 21:44
1. F1 LOTUS
2. Elanlover
3. rip
4. theelanman
5. esprit888
6. Mikeydude
7. Nige
8. TimHays
9. Candles (not really fussed either way, but if pressed, I prefer the groove)
Don't know if this project is still on, but due to sudden loss of income I'm going to have to remove myself. Sorry about that.
superbad
by abmunro » Tue 23.02.2010, 22:22
I would be interested if the other part of the handle that open the door could be fabricated as well.
Tony
abmunro
by Doug » Thu 09.12.2010, 02:47
Brian, what happened to this production? Not enough buyers?
- LEC Founder
by F1 LOTUS » Mon 13.12.2010, 04:57
Doug wrote:Brian, what happened to this production? Not enough buyers?
Combination of things Doug - mainly my not being able to find a satisfactory machining source to work with
However, I may have a reasonable source for aluminum casting, so I can get them to quote this route, and get some costs together
F1 LOTUS
by Doug » Thu 16.12.2010, 09:59
I just love the BMDB speed parts.
- LEC Founder
