Dico's project
Re: Dico's project
Postby Paul.P » Sat 08.08.2009, 07:48
Gary wrote:So is it taxed and one the road then ? :lol:
& more importantly, is it being driven on the road ?
Re: Dico's project
Postby Gary » Sat 08.08.2009, 07:54
and if so by who? :mrgreen:
Re: Dico's project
Postby Paul.P » Sat 08.08.2009, 08:15
Good question ?
Re: Dico's project
Postby rip » Sat 08.08.2009, 18:37
He's gone quiet. :shock:
Re: Dico's project
Postby Gary » Sun 09.08.2009, 07:26
again...
Re: Dico's project
Postby Paul.P » Sun 09.08.2009, 13:49
rip wrote:He's gone quiet. :shock:
Thats when you've gotta worry, don't know what he's up to ?
Re: Dico's project
Postby Monty » Tue 27.10.2009, 17:26
So the Turbo upgrade begins :shock:
Bling (except for the rusty bit lol, thats what you get for leaving it in the boot for so long :-D )
A little more room now
Test fit
Re: Dico's project
Postby lotusgirlmarie » Tue 27.10.2009, 17:53
Looks good so far. If you plan on using the oem heatshiels it's easier to install them before the turbo. BTW the bolts are in proper position for those that haven't done the upgrade yet. Again fantastique!!!
lotusgirlmarie
Goddess
Re: Dico's project
Postby Ekapol » Fri 30.10.2009, 22:44
Can't wait for when it's done and you go vroom vroom :burnout:
Ekapol
Re: Dico's project
Postby Dico » Mon 02.11.2009, 20:07
Vroom vroom, chug chug, vroom vroom vroom :D
Hall effect sensor to be fitted (by torchlight)
Re: Dico's project
Postby Monty » Mon 02.11.2009, 20:29
Well the Beast is back on the road
The only thing is, the poor thing is showing up a code 41 (HAS) but was ok before the install :? well it is on the original HAS
Waiting for the RC 550 injectors, then i can fit the 3 bar MAP sensor and i think Paul is ordering a Electronic Boost controller
Some quick photo`s
Intercooler pipe
Full install
Re: Dico's project
Postby theelanman » Mon 02.11.2009, 20:38
so once the car is up to speed you'll then have to try n speed dico up.....
back to the brillianteen.....or greeshun 200....... :-D :-D :-D
mind u ....having said that the cars been worked on for a couple of days so its about time he had 6 months off it....:)
Re: Dico's project
Postby RichardK » Mon 02.11.2009, 20:45
Well done Monty, that was really quick!! :shock:
Yep I'm going to have a look at the timing on mine....something not quite right ( probably just needs a tweak)
RichardK
Re: Dico's project
Postby Monty » Mon 02.11.2009, 21:02
Gareth, he now uses as his every day car, just hope he keeps an eye on oil pressure, temp and check water and oil levels :poke:
RichardK wrote:Well done Monty, that was really quick!! :shock:
Yeah i need to check Dico`s Elan too as it`s not ticking over as it did before the install, saying that that could be down to the CAS
BTW, your emails where a huge help :wink:
Re: Dico's project
Postby Dico » Mon 02.11.2009, 21:11
Oi yella shoes, shut up! :D
Yep, thanks a bunch Richard/Murph.m Almost there!!!!!
Re: Dico's project
Postby Dico » Fri 06.11.2009, 17:29
Injectors have arrived :D . Just need it to stop raining now so they can be fitted along with the 3 bar map sensor.
Currently running very well, and spooling up just as quickly as before. Everest chip still fitted at present.
Re: Dico's project
Postby Rambo » Fri 06.11.2009, 18:04
Monty wrote:Yeah i need to check Dico`s Elan too as it`s not ticking over as it did before the install, saying that that could be down to the CAS
More like the cobwebs in the air filter :twisted:
PS How much extra was your insurance for this upgrade Deeks :?:
Re: Dico's project
Postby Dico » Fri 06.11.2009, 18:43
An extra £120, at present...
Re: Dico's project
Postby Rambo » Sun 08.11.2009, 13:36
Are you still with Adrian Flux ? Or was it Carole Nash? Or then again Admiral? My memory is getting worse :?
Re: Dico's project
Postby Dico » Sun 08.11.2009, 13:41
Adrian Flux. They cover you for (Lotus only) track days free of charge so long as you inform them.
So i'll be Murph beating very soon...
Users browsing this forum: No registered users and 15 guests
