GeoffSmith wrote:Nice work - there are even some Lotus part numbers in there!
Indeed. The one I found earlier for frt spring was from
hereSearching for the rear spring is what found me the Monroe SP1337 number in the same place.
The rear S2 damper remains elusive so far.
A summary of what I and others have found so far:
NormasFront Spring/Damper Assembly: F100C0043F Yel/Yel/White
Parts Manual agrees with Specky's numbers
Front Spring: A100C0087H Yel/Yel/White (Concurs with Specks)
Front Damper: Original number C100C6015H R/B F100C6015F (S2 Type)
The Replaced By number agrees with Specky's number off the new assembly damper F100C6015.
Rear Spring/Damper assembly: Same as RowSE F100D0030F Grn/Yel/White R/B J100D0030J Grn/Yel/white (S2 type)
Rear Spring: Same as RowSE/S2 B100D0071F Grn/Yel/White Possibly Spidan (GKN) 55653
Rear Damper: Same as RowSE/S2 C100D6011H R/B E100D6011F (S2 type)
So everything except the front spring is the same as S2 setup.
FederalFront spring/damper assembly: C100C0123F Blue/Yel/Orange (Concurs with Specky)
Front Spring: A100C0126H Blue/Yel/Orange
Front damper: B100C6029H
Rear Spring/Damper Assembly: B100D0083F Red/Yel/Orange
Rear Spring: A100D0082H Red/Yel/Orange
Rear Damper: B100D6025H
So the whole setup is different to NA/RowSE/S2
RowSEFront Spring/Damper Assembly: F100C0077F Yel/Yel/Grn
Front Spring: B100C0086F Yel/Yel/Grn (Same part number and colours as S2) Possibly Spidan (GKN) number 55652 or Monroe SP1337
Rear Spring/Damper assembly: F100D0030F Grn/Yel/white R/B J100D0030J Grn/Yel/White (S2 type)
Rear Spring: Same as S2 B100D0071F Grn/Yel/White Possibly Spidan (GKN) 55653
Rear Damper: C100D6011H R/B E100D6011F (S2 type)
Hence it appears that the RowSE setup maybe replaced entirely by the S2 setup
S2Front Spring/Damper Assembly: H100C0077J Yel/Yel/Grn
Front Spring: B100C0086F Yel/Yel/Grn Possibly Spidan (GKN) 55652 or Monroe SP1337
Front Damper: F100C6015F
Rear Spring/Damper Assembly: J100D0030J Grn/Yel/White
Rear Spring: B100D0071F Possibly Spidan (GKN) 55653
Rear Damper: E100D6011F (This is the really elusive bugger)
Geoff: I've been thinking that a few people are researching this topic and having a place where different people can add information that they find regarding the suspension would be very useful. While I've the skills & resources to do something like this it would take considerable time and effort to setup and test. Time which is presently very short. Would there be any objection to using WikiLec for such a purpose as long as it got tidied up and summarised (or even deleted) when a result is obtained?
Thanks to all for their efforts so far. If anyone has any S2 dampers (particularly rear) they can read numbers off please let us know.
