A bit behind here but here's an update
Nitron have just about sorted the front and have come up with two options one is to retain the original top damper mount and the other is to use a pillow ball top mount.
The standard top mount will reduce the road noise transmitted into the car so may be the way to go for road cars and the pillow ball option is much more controlled in terms of damper position so should prove better on the track.
As far as final costs are concerned they are being calculated now including an all whistle and bells option with remote reservoir and multi adjustments for damping.
What I need now is a car to test the installation on and to fine tune the springs and damper rates, they have said they should be able to do it in a day if they start early so who's up for it once I have some firm prices, ideally a standard road car that is running standard suspension as this gives a good base point to work from, one that has had the suspension modified will not give us the best results so I will discount those at this stage (sorry Monty)
Bob
