Marcus_uk wrote:Here are the numbers for the S2 rear damper as they appear on the shock. If anyone locates some new ones please contact me asap as ive pulled the damper of my daily driver to get these numbers...
C100D6011H
- Made in England-
8116 2960 4HB
Gazza wrote:I will try at the weekend to get the codes from the old S2 rears i have in my mum's loft.
saska wrote:Rear Damper: ALL except Federal: E100D6011F Not Available
Marcus_uk wrote:Great work.... but im slightly confused :? Do you mean all rear dampers are available except the S2 ? (Fedral number is B1006025H, S2 = E100D6011F, SE = C100D6011H)
Gazza wrote:S2 Rears; C100D6011H - 8116 2960 5BALooking like there was never an S2 rear damper!!
Gazza
Gazza wrote:I changed mine at 42,000, roughly 4 years ago and can't see anything in the previous invoices. I don't have all from the first 5 years though.
Avonvilla wrote:Where do i look for the numbers etc bearing in mind there on the car !
Marcus_uk wrote:Avonvilla wrote:Where do i look for the numbers etc bearing in mind there on the car !
Have a look at that attachement I posted towards the top of this page. I took the numbers with the shock off the car, I dont know if you can do it with them still on... it might be possible though.
Gazza wrote:When you step out of the car turn right, they are in that direction!![]()
They are near the bottom of the dampers on the outer casing, but they might be hard to see depending on if they are facing outwards or not.
Avonvilla wrote:in the above pic they are near the bottom so is this the wheel end ?
