HJ2 wrote:Now it's to easy...
I'll let someone else play
Monty wrote:Is it that the bulb is missing for the Check engine light
esprit888 wrote:Monty wins round two !!![]()
as my SIR bulb is also missing in the first picture dapinky wrote:esprit888 wrote:Monty wins round two !!![]()
How does that work then? I posted before him! (and gave him all the clues to state the obvious answer)
But, as I say - the warning lights are not in the same place on Fed & UK models, so it may not have been obvious to many people on here.
(Good game, this - it does make you think about stuff we should - perhaps - all know, but often can't remember!)
Elanlover wrote:Colin, I used fibreglass reinforced body filler from good 'ole Canadian Tire for attaching a lot of the little peices to the back of the fascia panel during my fascia project. Holds it in there better than the original goo.
Elanlover wrote:Are you referring to the large silver box that you've positioned upright instead of flat as its normally situated? That's the DERM I believe. The smaller white one's the resistor module. All important stuff if you have an airbag.
Also, with regard to using epoxy. What I liked about the body filler was that I could smear it around quite a bit to reinforce the area around the offending piece as the foam was deteriorating. I was afraid that just gluing it would only secure it to the piece of foam that was breaking down. So, the piece would fall out again but with a bigger peice of foam around itJust have a look around the surrounding area to make sure the foam isn't breaking up to badly.
esprit888 wrote:Well i am going to give you 5 points for getting the DERM correctBUT, the way its mounted (vertically) is the way it came from the factory as it has three beefy bolts with a purpose built bracket holding it in that position. Incorrect on the resisitor module though, clue number 2, not so subtle
is below.
I couldn't remember which way the DERM was mounted as I changed the position on mine when I did the fascia project Elanlover wrote:esprit888 wrote:Well i am going to give you 5 points for getting the DERM correctBUT, the way its mounted (vertically) is the way it came from the factory as it has three beefy bolts with a purpose built bracket holding it in that position. Incorrect on the resisitor module though, clue number 2, not so subtle
is below.
Yep. From the pic I saw with the DERM module wires looking like they were running right into that box. I've never played with the resistor module so i guessed that might be it. Misleading Pics!!!!!I couldn't remember which way the DERM was mounted as I changed the position on mine when I did the fascia project
I'm thinking its the seatbelt logic module (now that you can read "logic" on it).
esprit888 wrote:Ok, the mystery pics/questions of the day are below. The first is what is it a picture of ? and what i need to know is what is the brown stuff Lotus used to hold it all together? (as i need to re-attach some items)
esprit888 wrote:I'm not Surprised this stumped so many as i had to go back and double check the part numbers to realize that the DERM is in fact the ECM (not to be confused with the ECU) so those 5 points have to come backAlso the other item (logic control) is primarily for the SIR but also operates the idiot chime i believe (lights on, key in ignition, seat belt not on) Its amazing once you get into it just how much extra there is on a federal M100 compared to a UK version. Take the knee crash pad for example, is this a swap out for the UK car ? (i have long legs and the Elise wheel helps but my knees still hit the crash pad) or is the entire lower dash different too?
