front lower wishbone (TCA)
Re: front lower wishbone (TCA)
Postby bobbrown » Fri 08.01.2010, 00:40
I do not have a problem supplying just the bushes as it will have an effect on the costs to produce these bushes and it is my intention to make the tooling available to LEC
Monty FYI: Inner bushes around £6.00 each, 4 required a side and £17.00 yoke to TCA 1 per side so total £41.00 per side.
I can get any of the bushes made to the same specification as the original or softer/harder it is the tooling that is the expensive part as the tooling costs are around £750.00 for each type of bush, cost to produce a bush is very low but it is a numbers game for example. 1 bush would cost £752.50 each but 50 cost £17.5each and 100 £10.00 each and so forth but once the tooling is made ........
This is one of the reasons the larger yoke to tca bush is more expensive than the inboard tca to chassis bushes as there are 4 per side of the latter.
This causes a bit of a dilemma as later runs of the bushes do not incur the cost of the tooling but I think that the extra should go to a LEC pot to allow other tools for other bushes or other bits etc to be made.
Bob
Pacific Blue N/A
bobbrown
Postby londoner » Fri 08.01.2010, 19:33
Bob,
any idea how much it weighs?
londoner
Postby Xen 11 » Sun 31.01.2010, 10:55
Hi bob, are we getting closer to a date where these are going to be available? My car is sidelined until I can replace :(
Xen 11
Postby bobbrown » Sun 31.01.2010, 14:28
I am going to make up the prototype arms, left and right over the next couple of weeks or so.
To move this project forward I am going to ask for deposit to help to fund the cost tooling and material as the intial outlay is likley to be in the region of £3000.00. I do not mind covering some of the initial cost but I can not cover it all.
To this end I would ask that those who can confirm their orderand wish to purchase complete wishbones to pay a deposit of £100.00 and those that want just bushes or ball joints pay 50% deposit.
Will start a list in the group buy viewtopic.php?f=85&t=16421 as it will be easier to track and as always I will be keeping a master record in Excel.
Bob
Pacific Blue N/A
bobbrown
Postby brian s » Wed 03.02.2010, 15:16
cutlea01 wrote:My order now has to be a proviosional order, redundancy at work, so I may not be able to afford them
1. bobbrown
2. Andy_J
3. pinky
4. saska (probably 2 sets - depending on price)
5. paulw
6. Jim B (Muley) possibly 2 sets if the price is right.
7. Kenich
8. MattDon (provisionaly if i can afford them, mine got the thumbs down today)
9.Woody.
10. Dico
11. Specky (possibly 2 sets if the price is right.)
12. Candles. (stainless if at all possible, with poly bushes and ball-joint)
13. John_W (with bushes & ball joint)
14. Denny
15. ashm (£ dep)
16. Richard K(inc ball joint and bushes pls)
17. inkitin
18. markv
19.Yasuo incl. ball-joint/bushes
20. stevieg8571 (cost dependant)
21. maz_r (also £ dependant)
22. Alan C (cutlea01) inc ball joints & bushes, black - Provisional enquiry
23. mvf906 ( £ dependant )
24. BFG in the BRG inc ball joints & bushes
25. Nige (possibly 2 sets, depending on price) Ball Joints and bushes as well please.
26. theelanman (£ dependant..inc ball joint and bushes)
27. rip
28. Ade
29. Niall (inc. ball joint and bushes)
30 baldyash bushes &b/joints inc
31 brian s. one set inc balljoints/bushes
brian s
Postby RayD » Sun 21.02.2010, 20:30
Copied from here
idlebanter wrote:Hi Everyone .... could these be a better replacement for the 8 inner wishbone polyflex bushes I purchased in june 09 from South West Lotus ? Or can someone illucidate more to a non techie guy
Reason for this possible dumb ass question is that I fitted 2 new front goodyear tyres 1 month later and having the camber, caster and toe aligned at the same time, only to discover Feb 2010 ,that my 2 front tyres have completly worn out on the inside..t
Took car to the alignment centre this sat where they proceeded to show me that these bushes had "gone" .... :(
Any thoughts,recommendations? :?
A few thoughts Paul,
Who fitted the bushes?
Have you complained to South West Lotus?
Presumably the people at the“alignment centre” are expert in setting camber and caster?
Where did they get the Élan settings from?
Did you take any pictures?
Ray
RayD
