RayD wrote:As Bob says, using the formula even for two identical springs ...
200 x 200 = 40,000 divided by 200 + 200 = 100
Placing a 100lb weight on two 200lb/in springs would cause them to compress ½” each.
Ray
RayD wrote:Phil, not being one for accepting things because they are too complicated to explain I tried to explain it ...
You are right in saying “Only if the springs were side by side would the compression be divided”
It is divided when they are side by side, it’s the reason a sprung mattress hardly moves when you lay on it.
When they are end to end it might be better to say the effect is multiplied.
With the two 200lb/in springs on top of each other the bottom one has the 100lb weight plus the weight of the top spring acting down on it. It would in fact move approx ½''
Ray
Elanlover wrote:I can't quite picture how changing the spring rates would raise the car up.
bobbrown wrote:Quite simple really. If the front had say 250 lb/inch springs and the load on the spring was say 750lbs then the spring would compress 3" if you substitute the 250lb spring for one of say 300lb/inch then the spring only compresses 2.5" for the same load.
rip wrote:A few questions to answer there...
My new springs are about 30% stiffer than the originals. It copes with bumps better than the originals, which I expect is because the old dampers were worn. The stiffness helps to keep the car flatter around a bend/roundabout. Dico & Gazza remarked about this when they took my car out the other night.
My Nitron dampers have spring collars to adjust the ride height. The spring will always stay the same length as its working length is determined by the weight of the car. If you want to raise the ride height, raise the spring collar. Unless you adjust it too far, the damper will stop the spring from compressing or expanding too far.
The anti-roll bar will provide the same resistance to rolling regardless of springs. Stiffer springs will add to this resistance so the overall effect will be that the car corners flatter.
I'm sure Bob will be along soon with some more answers & probably corrections to mine too.
RayD wrote:You would have thought the leading spring people would have a method of identifying within a few pounds what the original spring rate and length was.
bobbrown wrote:
There is a consideration of the motion ratio and damper angle to be taken into account as the load on the wheel will not be the same as the spring rates due to angles of the suspension and the motion ratio.
....So a 300 lb/in spring may only subjecting the wheel to 200 lb/in I do not have the figures but Eibach did the original calculations from parts, information and drawings I supplied.
In the case of the Type R it may well be the motion ratio 0.98 or 1.02 which is more typical for strut type suspension so a 350 lb/in spring gives just about 350 lb/in at the wheel.
So in our case a increase in spring rates from 300 lb/in to say 400 lb/in does not increase the stiffness by 1/3 but considerably less although the spring rates have gone up by 33%
In the case of the test car we probably only increased the "stiffness" by around 10% and in the case of the track day cars it may go up by 50% although the spring rates will probably be + 500 lb/in an increase in excess of 75%
As I have said before it is quite complex with a lot of number crunching
