rip wrote:Emissions should not be a problem for you because your S2 is a '95 & therefore has to conform to the 'old' emmission standards.
Your sports cat may protect against overboost a little more than a straight-through system though.
speed-demon wrote:I think Geoff was running an S2 with no cat's and passing emissions...
speed-demon wrote:One thing I will say about porting. Is that after, the drivability of my car returned to that of pre messing with the exhaust etc. So now I have all the benefits of the Piper but with a car that feels like Lotus intended. But less power than prior to porting but more power than when the bloody thing used to go to fuel cut in the outside lane of the motorway. Not good!
speed-demon wrote:I have an Everest chip.....
I wish I could have the madness with the driveability of the ported car.
rip wrote: I set my timing by stopwatch, used Elanscan to check that I am getting no knock & found it now runs best at 32btdc???
ailwyn wrote:rip wrote: I set my timing by stopwatch, used Elanscan to check that I am getting no knock & found it now runs best at 32btdc???
How do you set the engine by stopwatch?
Seems quite a coincidence that your timing has ended up at exactly 2x the handbook![]()
Can anyone explain?
MPx wrote:Faced the same dilemma when I bought mine. I went conservative cos I'm not chasing the last n BHP or db. In fact I dont yet know if its paid off cos I've not had my next MOT yet...but I'm hoping my decision to use the 2 1/4 with Sports Cat will see it sail through (despite also removing the pre-cat and porting). Of course if it doesn't then the rest of you guys with 2 1/2s and/or no sports cat are in deep doos !
lotos wrote:You got the cat and still failed on emissions?
MPx wrote:He also said that the="MPx"] regs changed in 1992 so everything registered since and some from 1992 have to be tested as catted.
rip wrote: 1992? Query that. I read somewhere on this very forum .........
