bobbrown wrote:You could try http://www.isuzuparts.com/index.html not sure if they ship outside of the states if they don't I'm sure something can be organised and cheaper than pattern part.
Bob
PLEASE NOTE: The 4XE1 DOHC 1.6 liter Non-turbo, 4XE1 DOHC 1.6 liter Turbo, and 4XF1 DOHC 1.8 liter Non-turbo engines use DIFFERENT PATTERN HEADGASKETS. Water flow through the block is controlled by the shape and size of the water jacket openings in the head gasket.
Using a 1.6 liter Turbo or 1.8 liter head gasket on a 1.6 liter Non-turbo engine will result in engine temperatures too low for the oil to properly lubricate the engine, resulting in rapid bearing wear and engine failure.
Using a 1.6 liter Non-turbo or 1.8 liter Non-turbo head gasket on a Turbocharged engine will result in inadequate engine cooling, overheating, oil breakdown and lubricant failure, head warpage, cracks in the engine's water jacket, and destruction of the engine.
- assuming they are still where i sent them )Users browsing this forum: No registered users and 3 guests
