Monty wrote:dapinky wrote:Just as a thought - you shouldn't allow the MOT tester to do the front (driven) wheels on a brake roller with an LSD fitted - It'll bugger the whole lot up!
Well how do you get a pass on the MOT if you don`t allow them to test the front![]()
Since the ATB doesn`t use a clutch type system then it no probs for the pink bomb
Dico wrote:Good work Murph/Bob. You just need to lay off the Ulster fry's now.
Paul.P wrote:Thats put a different perspectic on it then Nige, i know what you mean about the rear end going light with front brake upgrade, but why wouldn't you want to put it on a road car ?
Monty wrote:Well Pinky passed it`s MOT test today with no problems![]()
Here`s the result of the brake test (only estimated as it`s the old dial type gauge)
This is with Bob Browns 16" Wilwood Dynapro 294mm Disc front conversion with Yellowstuff pads and Bob`s Hi-spec rear conversion, 262mm Disc and Mintex MNB 1890 pads
.....................N/S.........O/S
Rear................100.........100
Handbrake.........120.........130
Front...............330.........350
Balance.............170........170
Looks like the Rear brake is slightly better but the Handbrake wasn`t as good as last year![]()
Last years
Brains front 16" wilwood kit with Yellowstuff
Stock rears but with Bob`s sliding pins fitted and EBC standard padsHere`s the results of the brake test
Rear................90..........90
Handbrake......160........160
Front..............330........360
Balance..........200........200
rip wrote:Looks good, Monty.
I thought you would go for the CF panel...or did some **** grab the last one?
that was suppose to be mine Monty wrote: what configuration have you got your lights?
Monty wrote:
BTW, what configuration have you got your lights?
Dapinky wrote:
Biggest decision has been on the colour to paint it - She wants Red, I want Blue
Now I've seen this one, I'm settled on either Graphite Grey, or Satin Black - then it can go on either car
rip wrote:I like separate lights for brake & tail but I have thought about moving the brake lights inboard & completing the outer rings for tail lights. I've not even looked at it though, can this be done?
surfboardfiller wrote:I never had a problem with an MOT for the past 3 years, I think you can safely say it's lit.![]()
Did you try LED bulbs in the light units to reduce the load on the fuzes?
