ELISE REAR LIGHTS
ELISE REAR LIGHTS
Postby J46_MAV » Thu 20.05.2010, 12:05
Have fitted newly acquired light pods with Elise lights (one side only fitted so far). I had the same issues as others with the 5A fuse blowing so replaced them with 7.5A (there's one fuse for each side).
Not sure I've got the ideal configuration for stop/tail lights but I can work on that once both sides are fitted.
As a temporary measure, I sprayed them up with satin black and the effect is pretty good I think. Not sure if it will last so will get them sprayed properly when I have the front end done. I was thinking of having them done body colour but the black fits in well with the other trim.
91SE in Pacific Blue
44,000 miles
Bought in December 1991 from Mann Egerton, St Ives
J46_MAV
Re: ELISE REAR LIGHTS
Postby rip » Thu 20.05.2010, 14:27
J46_MAV wrote:I was thinking of having them done body colour but the black fits in well with the other trim.
I think that black creates a nice contrast with the body colour.
If you find that it shows the dirt/dust a little too easily, then how about dark grey/charcoal?
You could try photoshopping it?
Postby Aoki Magic Pants » Thu 20.05.2010, 15:21
Oh that looks good! I haven't had my pods sprayed yet, but I'm tempted to get them done black now - at least I wouldn't have to worry about getting an exact match on the paint!
Aoki Magic Pants
Postby rip » Thu 20.05.2010, 19:56
How about dark grey?
This panel is unpainted CF with the weave visible :-D
Postby J46_MAV » Fri 21.05.2010, 20:16
I like the grey/anthracite with Calypso red.......
..... but the satin black goes well with the black 'eyebrows' over the lights and black detail on the number plate. I'll probably leave it like this. Next job is black wheels then!
44,000 miles
J46_MAV
Postby Monty » Sat 22.05.2010, 10:56
They do look good in black, like you said it matches the plinth etc :-D
Postby smilerbaker » Mon 26.07.2010, 17:41
where do you get the conversion panels from ?
smilerbaker
Postby J46_MAV » Tue 27.07.2010, 14:01
I bought mine second-hand off another LEC member so not sure where they originated from. My guess is a small production run by another LEC member a few years ago. They won't be available off the shelf anywhere.
44,000 miles
J46_MAV
Postby lotusgirlmarie » Tue 27.07.2010, 18:27
They were my original panels. I built them a few years back.
lotusgirlmarie
Goddess
Postby Brit-Car-Nut » Tue 27.07.2010, 19:35
Any chance of making a few more? Seems to be a nice solution for someone that doesn't want to change the entire rear end.
Thanks.
Postby lotusgirlmarie » Wed 28.07.2010, 00:49
Unfortunately not. Those were a one off deal because I disliked the OEM lights so much. No mould, dimensions, or tooling exists for them. Only thing I can tell you about them is that they're made from ABS plastic and that the took a long while to make.
lotusgirlmarie
Goddess
Postby Brit-Car-Nut » Wed 28.07.2010, 02:17
Thanks for letting me know.
