Hard Top - Now Obsolete
Re: Hard Top
Postby clemo » Fri 30.04.2004, 10:36
dude !!<br>class , bring em on...<br><br>however <br>maybe a exeige style roof vent !!!<br>or some detail lines front to back channels.<br><br>like the rear window going all the way to the hood stowage ..<br><br>i'll have 1..<br><br>clemo
clemo
Re: Hard Top
Postby greg » Fri 30.04.2004, 11:53
Why not make it with the whole rear deck.<br><br>Ie you remove your deck, and screw this on, drop it down and latch onto the hood front latches.<br><br>Or you'd need some decent clamps to latchonto the front of the reat deck.<br><br>Looks great BTW!
greg
Re: Hard Top
Postby grahamec » Fri 30.04.2004, 14:04
Kuching<br>Interest from me to.<br>Grahame
grahamec
Re: Hard Top
Postby Paul.P » Fri 30.04.2004, 18:00
Looks pretty damn good to me ! ;D
Re: Hard Top
Postby Neil D. » Fri 30.04.2004, 18:44
Nice design, now the list of options ;-)<br><br>Heated rear screen,<br>Roof rack attachments to fit my skis ;-)))<br>Interior lite, to improve on the current.<br><br>Could it be fitted to the location where the seat belts dissappear down behind the seats ?<br><br>like it a lot<br><br>Neil<br>
S2 # 541
Neil D.
Re: Hard Top
Postby Kuching » Fri 30.04.2004, 19:08
Thanks for all the encouraging comments   [smiley=wave.gif]<br>Due to popular demand I have attached a few more pictures. I think the sexy curves suit the overall styling of the car, but I will try a slightly more square version.<br><br>The rear deck/hood cover will be integral with the roof and replace the original deck, but this should be only a 2 minute job to remove or replace the 4 screws. The convertable hood could also be removed for weight saving. As for timescale, I am determined to have a roof on my car before next winter. I don't want to guess at the cost until I have shown the model to the pattern makers and laminators. [smiley=dontknow.gif]<br><br>Image<br><br>Image
Kuching
Re: Hard Top
Postby Doug » Fri 30.04.2004, 20:00
[quote author=Neil D. link=board=body;num=1081474915;start=15#26 date=04/30/04 at 10:44:54]Nice design, now the list of options ;-)<br><br>Heated rear screen,<br>Roof rack attachments to fit my skis ;-)))<br>Interior lite, to improve on the current.<br><br>Could it be fitted to the location where the seat belts dissappear down behind the seats ?<br><br>like it a lot<br><br>Neil<br>[/quote]<br>How about a rear muzzle gun on each side  [smiley=bazooka.gif]<br>rear oil slick spray<br>tire tack ejector<br>rear view camera<br>photoelectric LCD type rear window to control clear-tint-black out effects<br><br>cool, so if it attaches to the hinges of the stowage lid then it will open and tilt up real high  :o<br>only problem is this set-up is not convenient for frequent changes--more of a "seasonal change" only.<br><br>and if you can't accomodate all those options it okay  :-*
Re: Hard Top
Postby Sy V » Sat 01.05.2004, 06:10
What are you intending to use as seals around the header rail and door window areas?
LEC Godfather
Re: Hard Top
Postby Kuching » Sun 02.05.2004, 13:40
I do understand your concerns, however, sealing the roof effectively will be the main focus of my attention.  There is a rubber extrusion company that I deal with who have some very useful standard sections.  Although there are none that would fit the convertable hood, designing the new roof to suit the available sections should be very effective.<br><br>
Kuching
Re: Hard Top
Postby Sy V » Sun 02.05.2004, 17:37
"...designing the new roof to suit the available sections should be very effective."2<br><br>No.<br><br>That would be a quantum leap!  The best of British luck to you.
LEC Godfather
Re: Hard Top
Postby Neil D. » Mon 03.05.2004, 19:16
On a side note, what type of CMM do you have access to ? <br>I user a Romer arm , I was just intrested<br><br>Cheers<br><br>Neil
S2 # 541
Neil D.
Re: Hard Top
Postby Kuching » Tue 04.05.2004, 18:44
Neil, I have a choice of 2 FARO Arms (similar to the Romer), one with a 12 foot (3.66m) working diameter and also an 8 foot (2.44m) arm with an accuracy of about 70 microns.
Kuching
Re: Hard Top
Postby Doug » Tue 04.05.2004, 19:08
[quote author=Kuching link=board=body;num=1081474915;start=30#33 date=05/04/04 at 10:44:11]Neil, I have a choice of 2 FARO Arms (similar to the Romer), one with a 12 foot (3.66m) working diameter and also an 8 foot (2.44m) arm with an accuracy of about 70 microns.[/quote]<br><br> [smiley=werd.gif]<br><br> ;)<br><br>I have 2 arms too   8)<br>
Re: Hard Top
Postby Kuching » Tue 04.05.2004, 19:21
Luckily my legs are much shorter and more evenly matched! [smiley=shakin.gif]<br><br>Simon
Kuching
Re: Hard Top
Postby Doug » Tue 04.05.2004, 19:55
You know what they say about long arms . . . . . . . <br><br><br><br><br><br><br><br><br><br><br><br><br><br><br>they require long sleeves!   ;)
Re: Hard Top
Postby Neil D. » Tue 04.05.2004, 20:40
Intersting that you are using Faro (s), thay have the nice option of indefinite rotation, don't they.<br>We have the first Romer with 720 on the A encoder, still the interface with Delcam software is a pain.  However we are good to 80 microns with our 2800 mm reach.<br><br>as for the hard top, looks real nice. If you need any help ( measurements or else ) drop me a line.<br><br>Cheers<br><br>Neil  ( only one arm )<br><br>
S2 # 541
Neil D.
Re: Hard Top
Postby Kuching » Wed 05.05.2004, 23:17
Thanks for the generous offer Neil. It would be interesting to make some comparative measurements between two different Elans. <br><br>I will send you an e-mail to follow this up.<br><br>Simon<br>
Kuching
Re: Hard Top
Postby Paul.P » Thu 06.05.2004, 20:36
I am also trying to get a hardtop made for me, by some very clever body shop people just down the road. They are on about covering the soft top with plastic sheeting, then covering it all with expanding foam to make a mould. One of the blokes has made some really nice one off body panels for customers cars & seems really keen, so will keep you all posted.
Users browsing this forum: Google [Bot] and 2 guests
