bobbrown wrote:Measured the two "O" rings and they are as follows
smaller one is 3.75 mm id and 1.8 mm cross section
larger one is 7.1 mm id and 1.8 mm cross section
It is very important to select the correct material as some materials are not compatable with brake fluid! so do not just pick them out of a box of standard O rings
bobbrown wrote:To progress this to a conclusion I need to know how many people would be interested
I have the spring spec to convert a Vauxhall valve at 3/what ever to 3/15 so I can get the springs made
Spring rate 4.58 N/mm
33mm long
14.1 od
10.9 id
16 gauge wire diameter
7 coils ground ends
I have a wholesale supplier that may be willing to sell his stock all be it limited of Vauxhall valves so that may give us 50 or so
I can get the end that allows the valve to be fitted in the fixed pipe work made to eliminate the problem with stripped threads
Cost at a calculated guess about £35.00 each for a complete replacement unit.
Bob
bobbrown wrote:I'm dropping this and not doing any more work on it.
