Head Gasket Kit
Re: Head Gasket Kit
Postby Monty » Tue 06.07.2010, 09:13
I just measured the material bit, actually a little difficult to measuer as there`s ridges/bumps etc but i never measured the main ring thickness. I`ll have another measure but can`t measure the AJUSA one as thats now on Pauls car :roll:
IMHO the lotus gasket doesn`t compress that much hence why you don`t need to recheck the head bolts.
Re: Head Gasket Kit
Postby bobbrown » Tue 06.07.2010, 09:57
Monty wrote:IMHO the lotus gasket doesn`t compress that much hence why you don`t need to recheck the head bolts.
So what is the thickness of a NEW genuine gasket?
Pacific Blue N/A
bobbrown
Re: Head Gasket Kit
Postby Breed » Tue 06.07.2010, 12:59
Dont know if its any help but Piper exhausts have a gasket making service by an american company and they will quote from a sample. They will also change them to meet your specifications. So if anyone has a original to lend them to get the quote it may be that it could be a source for a ongoing supply. The contact at Pipers for the gaskets is Peter and he is in the same office as the exhaust guys so the contact number is the same. When I spoke to them they said that to get it to about $40 dollars a gasket they would look for a order of about 10. Can't do any harm getting a quote but I do not have a head gasket to send them.
Bill
Breed
Re: Head Gasket Kit
Postby bobbrown » Tue 06.07.2010, 14:28
Breed wrote:Dont know if its any help but Piper exhausts have a gasket making service by an american company and they will quote from a sample. They will also change them to meet your specifications. So if anyone has a original to lend them to get the quote it may be that it could be a source for a ongoing supply. The contact at Pipers for the gaskets is Peter and he is in the same office as the exhaust guys so the contact number is the same. When I spoke to them they said that to get it to about $40 dollars a gasket they would look for a order of about 10. Can't do any harm getting a quote but I do not have a head gasket to send them.
Bill
That may be all well and good BUT the issue is with aftermarket gaskets failing and this would be another aftermarket option and it would be difficult to know how they stand the test of time after all most of the originals have been on cars for over 16 years assuming they have never been changed.
I do appreciate that the gasket specification could be changed but to what, as it is all very well having the resources to test them but I do not think people would be up to changing the gasket more than is really needed and most myself included would only do it in the event of a head gasket failure.
I suppose if the originals were giving problems on cars with higher engine outputs then a gasket more in line with a competition one may be an option but they would be more expensive. I am thinking multi layered steel as used in Cosworth engines and they could be made by Cometic Gasket Inc in the USA as some of the Cosworth ones are but they would be much more expensive. These are also critical in terms of surface finish as the head to block faces do move and need to be 50RA or better.
Bob
Pacific Blue N/A
bobbrown
Re: Head Gasket Kit
Postby lotuska » Tue 06.07.2010, 20:17
We've been round the head gasket problems before, comparing a replacement with an original Lotus one, check out the following link, this includes pictures and thickness etc.
Check the 4th post from the end on the link above.
Hope that helps.
lotuska
Re: Head Gasket Kit
Postby GeoffSmith » Tue 06.07.2010, 20:24
That's why I couldn't find it - cunningly concealed in a "Valve Stem Oil Seal Replacement" thread! :D
Re: Head Gasket Kit
Postby dapinky » Wed 07.07.2010, 01:29
GeoffSmith wrote:That's why I couldn't find it - cunningly concealed in a "Valve Stem Oil Seal Replacement" thread! :D
If it were any more cunning, you could tie a tail on it and call it a weasel, Baldrick!!!!
Re: Head Gasket Kit
Postby Monty » Wed 07.07.2010, 17:36
From the other Link
lotuska wrote:Firstly I checked the thickness of each head gasket using my trusty micrometer...
Thickness of gasket material
- Lotus Original 1.22mm
- kmckmcs replacement 1.65mm
Thickness of "metal" bits around cylinders etc
- Lotus Original 1.35mm
- kmckmcs replacement 1.75mm
Monty wrote:I could only do mine with digital calipers :roll:
Few approx measurements of Turbo Head Gaskets:-
Dico`s old USED stock HG (Silver)
Thickness- 1.21mm cylinder ring (Crushed)
Bore 80.8mm
Dico`s New aftermarket replacement AJUSA (dark grey)
Thickness- 1.28mm Material
Bore 81mm
Kmckmc`s HG (Black)
Thickness- 1.70mm cylinder ring
Material 1.65mm :shock:
Bore 81.2mm
Re: Head Gasket Kit
Postby Specky » Wed 07.07.2010, 18:50
Lotus N/A
Internal diameter 81.1 cm
Thickness 1.3 mm
Re: Head Gasket Kit
Postby bobbrown » Sat 10.07.2010, 10:41
While having a little trawl on the internet I did find this little gem and it is worth noting.
"PLEASE NOTE: The 4XE1 DOHC 1.6 liter Non-turbo, 4XE1 DOHC 1.6 liter Turbo, use DIFFERENT PATTERN HEADGASKETS. Water flow through the block is controlled by the shape and size of the water jacket openings in the head gasket.
Using a 1.6 liter Turbo on a 1.6 liter Non-turbo engine will result in engine temperatures too low for the oil to properly lubricate the engine, resulting in rapid bearing wear and engine failure.
Using a 1.6 liter Non-turbo on a Turbocharged engine will result in inadequate engine cooling, overheating, oil breakdown and lubricant failure, head warpage, cracks in the engine's water jacket, and destruction of the engine."
Which explains why there are two different head gaskets, modifying the gasket where the water ways are could be detrimental.
Also the part number for some of the aftermarket head gaskets is the same for the non turbo and the turbo engines, so it may they have not got the cooling quite right and this may lead to head gasket failure.
Bob
Pacific Blue N/A
bobbrown
Re: Head Gasket Kit
Postby Dico » Sat 10.07.2010, 12:44
After changing my non original gasket my tempreature gauge fluctuates slightly. I can only pray Christopher Neils supplied the turbo version :shock:
Re: Head Gasket Kit
Postby GeoffSmith » Sat 10.07.2010, 15:22
bobbrown wrote:While having a little trawl on the internet I did find this little gem and it is worth noting.
Bob
Link?
Keep up at the back! :lol:
Re: Head Gasket Kit
Postby Ekapol » Fri 13.08.2010, 01:11
It costed me enough after few head gasket jobs. I stick with OEM Lotus (or Isuzu) head gasket from now on. :-)
Ekapol
Return to Engine
