PECKHS wrote:need some advice urgently
previously there was white smoke coming from the exhaust when i start the car. the smoke never goes away, so i thought it was the valve stem seal.
changed the valve stem seals i bought from SJS, and the smoke sitation was not solved.
before i start dismantling the engine to pieces, i need some advise.
3 of the plugs are soaked with oil, only 1 is clean.
the turbo pipes and such are dry, no traces of oil.
the smoke gets worse after the car warms up, lesser when it is cold.
questions:
1. other than the valve seals, what else could fail and cause oil to flow into the engine?
2. what does oil soaked plugs indicates?
3. how can i check what is causing the oil leaking into the engine?
4. the porbable cause i can think of is the piston o-rings or head gasket. any other probability?
5. can elanscan help to narrow down the problem?
any advise appreciated urgently.
tks
Enright wrote:Have you done a compression test? If so what were the results?
PECKHS wrote:yes, did the compression test, was about 110-120..
ashm wrote:PECKHS wrote:yes, did the compression test, was about 110-120..
I'd suspect the head gasket or rings. Check out other people's compression test results here. Most are around 150-160 or so...
Maybe try dry & wet compression tests to see if there's a difference - might help you narrow it down to the HG or rings.
Adam
PECKHS wrote:Enright wrote:Have you done a compression test? If so what were the results?
there was oil on the 4 pistons
my friend is insisting the problem lies on the piston rings..
bobbrown wrote:There is one thing I do not quite get, if you have already changed the valve stem seals how was this done?
I know it is possible to do them in place but a right pain and it is more normal to remove the head.
As for rebuilding the engine I would expect an Elan engine to do lots more than 100K and many have mine included 128k and climbing.
If you get low compression figures across the engine then I would suspect something else is going on as it is unusual for all 4 to be down with a head gasket failure, just as I would not expect all the pistons/rings to have failed at the same time.
One minor point was the throttle fully open when you checked the compression if not that may go some way to explaining the low compression.
Specky wrote:You'll need to remove all the spark plugs and measure one piston at a time. This way you are only measuring the compression of that cylinder. (There will be no discernible feedback from the other cylinders).
Don't forget to disconect the LT side of the coils (Satety first)
Do a cold reading and a warm reading takeing note of where you want the throttle for the test.
One question... Is your mechanic really a mechanic....![]()
