Drivetrain problems
by dkellis » Wed 20.10.2010, 00:25
Hi,
I have run across a limited-slip differential that's available and I'm thinking of buying it because I'm going to start autocrossing my M100.
What's involved in fitting it? Do you have to pull the engine?
Also, in another post on LEC someone mentioned that an LSD will cause understeer. Seems that could be counterproductive.
Can anyone offer the benefit of their experience?
Thanks,
Seattle, WA, USA
dkellis
by racerstev » Wed 20.10.2010, 14:51
It's a big job, you need to drop te trans and split the case but the engine can stay in place. I have
one to install over the winter myself.
For autocross, these no bigger improvment then a Quaife. You won't really feel a differance in grip but
you will feel it off the corner big time!
racerstev
by dkellis » Wed 20.10.2010, 16:01
racerstev,
Thanks for the info. Now to decide how brave I am...
Seattle, WA, USA
dkellis
by racerstev » Wed 20.10.2010, 20:57
Be sure to read the manual, there are some shift interlock pins that need to go back the right
way..
racerstev
by dkellis » Wed 20.10.2010, 21:14
racerstev,
Speaking of the manual, is there somewhere I can get paper copies of the manual(s), including the one on closed loop operation?
I got the downloaded version of the scanned manual a while ago and (a) it's illegible on my windows machine and (b) each page has some obtrusive watermark on it.
I'll also post this request in a more general forum.
Thanks,
Seattle, WA, USA
dkellis
by racerstev » Thu 21.10.2010, 00:02
I got mine on E Bay
racerstev
by dunnlor » Thu 21.10.2010, 00:38
They're also available through Dave Bean.
- dunnlor
dunnlor
by lotusgirlmarie » Thu 21.10.2010, 06:10
Just my 2p but when you replace the diff buy a new speedo ring gear and all new driveshaft seals. Might as well do them all while it's apart. The ring gear also has a nasty habit of breaking while trying to remove it from the OEM diff. Better to just buy new and forego the headache.
lotusgirlmarie
- Goddess
