PECKHS wrote:i was just wondering. we are very sure the engine has been changed. but which engine was used? could it be a 4XE1W from the isuzu impulse rs which was used as a replacement ???![]()
could the 4XE1W have used a oil pressure sensor with a different thread???
tigerdog wrote:PECKHS wrote:i was just wondering. we are very sure the engine has been changed. but which engine was used? could it be a 4XE1W from the isuzu impulse rs which was used as a replacement ???![]()
Check out the Hot to Trot thread. A few years back, Doc Fizzix bought an Isuzu engine and rebuilt it for use in his Elan. He carefully cataloged the differences he found between his engine and the Lotus item. Maybe the sensor is mentioned.
PECKHS wrote:bad news, new sensor didn't fit![]()
gonna try one last time next week by going to some big spare parts shops in town and try to look for an alternative from a japanese car
if nothing suitable is found i will have to take a bet and use back the original sensor
correct me if i'm worng... the oil pressure sensor is a reading device only, or does it has other functions? other than sending signals to the pressure gauge and oil pressure light, does the ECM relies on the signal/voltages to control and/or regulate the engine?
can the elanscan read the oil pressure?
getting extremely restless with the no-go elan. i really must take a drive in it to rekindle the feelings i had when i just bought the car...
PECKHS wrote:correct me if i'm worng... the oil pressure sensor is a reading device only, or does it has other functions?
bobbrown wrote:VDO list a BSPT sender with a warning contact over here!
Range /Thread /Warning Contact/# On Sender/ Part No.
0-150 PSI /1/8-28 BSP/ 7.0 PSI/ 30/66/ 360 083
Bob
PECKHS wrote:The shop will be using copper to fabricate the adapter... will using copper instead of brass going to be an issue??
tks
peck
Brit-Car-Nut wrote:Sorry. Grabbed the wrong link. From that page there is this link: BSP adapters
There is one for 1/8 BSPT to 1/8 NPT: 1/8 NPT Female to 1/8 BSPT Male
I would also look into getting a M10x1 sender and getting it re-tapped to the 1/8 BSPT as the M10x1 is a bit larger in diameter.
