Dico wrote:Hi Crambury
Can you confirm 100% these gaskets will fit our UK Turbo'd Elan? And did you get a final price?
A very interesting thread you have going over there.
Cheers, Dico.
only difference i see from my CAD is the water jackets on the ends of the block by cyl. 1 and 4. i have an used HG for the RS at home in my parts car. i'll have to double check, but last i remember the ports were SUPPOSED to be round, not elongated to restrict water flow for the purposes of capturing/transmitting more heat from the block into the coolant.
my CAD looks EXACTLY like the GENUINE LOTUS gasket.
and from the thread link above:
bobbrown wrote:While having a little trawl on the internet I did find this little gem and it is worth noting.
"PLEASE NOTE: The 4XE1 DOHC 1.6 liter Non-turbo, 4XE1 DOHC 1.6 liter Turbo, use DIFFERENT PATTERN HEADGASKETS. Water flow through the block is controlled by the shape and size of the water jacket openings in the head gasket.
Using a 1.6 liter Turbo on a 1.6 liter Non-turbo engine will result in engine temperatures too low for the oil to properly lubricate the engine, resulting in rapid bearing wear and engine failure.
Using a 1.6 liter Non-turbo on a Turbocharged engine will result in inadequate engine cooling, overheating, oil breakdown and lubricant failure, head warpage, cracks in the engine's water jacket, and destruction of the engine."
Which explains why there are two different head gaskets, modifying the gasket where the water ways are could be detrimental.
Also the part number for some of the aftermarket head gaskets is the same for the non turbo and the turbo engines, so it may they have not got the cooling quite right and this may lead to head gasket failure.
Bob
in short, looks like we can modify the TURBO gasket for an NA, just not the other way around.
if the embossing of the port is made to the shape of the NA it will still seal and allow NA users to take a carbide bit to the gasket while maintaining a seal for their application.
funny thing is, i run 160F thermostat instead of the 180F OEM. so i will take the round ports to capture more heat until i upgrade my radiator and get back to an OEM thermostat.
