Drivetrain problems
by tigerdog » Fri 28.01.2011, 19:53
If that doesn't work out, Steve, check out
Clutch Specialties. They did the uprated pressure plate and six-puck disc that's currently in Smaug. Definitely works out the left leg but doesn't slip and holds nicely on steep uphills at 17PSI boost in 4th.
by racerstev » Fri 28.01.2011, 22:26
Thanks but I'm trying to avoid a heavy pressure plate, it's hard to be smooth with a stiff clutch.
One issue with mine I need to address is the cable, even with a stock PP it seems to move half way before
the rubber compress's and the clutch starts to disengage. It must be worse with a stiff plate...
I guess the plan is to remove all the rubber donuts on the cable and replace then with solid spacers.
Steve
racerstev
by tigerdog » Sat 29.01.2011, 19:17
racerstev wrote:Thanks but I'm trying to avoid a heavy pressure plate, it's hard to be smooth with a stiff clutch.
It's all in the leg muscles, my friend. You may find the lightened flywheel prevents smooth starts more than a stiff clutch. At least that's my experience - it's much easier to stall when trying to start smoothly.
by racerstev » Sun 30.01.2011, 17:05
It's not the starting as much as the driving, stiff clutch's are annoying. I really liked the light flywheel in
my last car, it woke it up a good bit.
I'm trying to make a really fast car that is pleasent to drive. Not a really fast car that get's on my last nerve.
It always seems to go that way, the faster the car the less fun it is to drive when not going fast...
Steve
racerstev
by tb10 » Mon 14.04.2014, 19:48
Dear All,
I'm looking for an uprated clutch as mine is starting to slip. Does anyone have one that they may consider selling or where is the best place to obtain a performance one?
Kind Regards,
tb10
by racerstev » Tue 15.04.2014, 03:40
http://hrclutch.com/contactUs.htmlMine worked out real nice. It's pretty smooth but with the light flywheel you need
to be careful pulling away from a light. A few more rpm is all you need, once rolling it feels
like a stock clutch SO far it has held a set of slicks and 15-17 pounds of boost.
Steve
racerstev
by tb10 » Tue 15.04.2014, 09:28
Cheers Steve for the swift reply.
I'm not stateside but may well be in the summer! It's an option so much appreciated.
Kind regards
tb10
by chrisP » Mon 22.06.2020, 14:16
Old topic resurrection warning..... Has anyone suggestions for a UK based uprated cluch kit?
Thanks Chris
chrisP
