JonT wrote:Been out for a run for the first time with ElanScan. No major issues, but looking at the boost graph it's only making 0.55-0.6 bar max. I've got the Everest 1499 chip so was expecting a bit more - that seems like standard? Throttle log shows I was reaching full throttle and the top of the boost graph is flat, suggesting it's being held at ~0.55 bar. Wastegate duty cycle shows 80% around these readings. Does that mean it's sticking? No knock recorded. Injector duty also shows around 80% max.
Any thoughts about why I might not be making more boost?
saska wrote:Jon, looking at your scan the following points are of note:
1. You're making ~190Hp @ 6300RPM in 3rd gear which may be a calculated value but nevertheless is very decent output.
5. Check there isn't a fuel cut defenser, blow off valve, BBR kit, etc
John_W wrote:Elanscan doesn't show base timing, only dynamic advance. You have to set base timing using a strobe light and the timing marks on the crankshaft pulley while the ECU is in Service Mode (use a paperclip to bridge the black and black/white wires on the ALDL plug under the glove box - see here.).
However that will not be the reason you're not seeing the expected boost; incorrect base timing would result in the available boost not being used efficiently.
tigerdog wrote:Ignore the bit about the TPS - the first scan looks fine. However, I have a hunch: is it possible your car is fitted with a 3BAR MAP sensor? I ask because Smaug has a 3Bar plus 550cc injectors. In order for ElanScan to show the correct boost, you have to change a value in ElanScan's .ini file. I happened to open your scan with the 3Bar value in place and noticed peak boost at .9 Bar.
JonT wrote:Doing a bit more searching seems to suggest that if a 3 bar map sensor was fitted the baro pressure in elanscan would show 0.71 bar? (viewtopic.php?f=34&t=18187&p=237839&hilit=+bar+map#p237839), but the baro pressure looks normal in mine. Hmmm....
JonT wrote:The map sensor post above made me realise there are probably more hoses off the inlet manifold/plenum that I haven't checked. I guess they're all potential sources of leaks?
In the meantime - am I likely to be doing the car any harm by continuing to use it?
