The original has the numbers : 09-24894 0093 on it, while the new one has: 09-24894 7073 on it. It also has a lot of white powdery stuff on it, which I believe is corrosion. you can see that in the pictures. Will that corrosion hurt anything?
dermotbell wrote:I am guessing that if as I suspect one of the resistors has gone the next question will be where the hell do I get a replacement? Is there a parts cross reference?
donsladek wrote:Tweetdriver63 wrote:
I'm betting the white material is a ceramic type cement (such as Sauereisen) used to keep everything stable.
GeoffSmith wrote: but was only aware of 4 position (plus off) fans and like John, I can't see why they would be different. I think John is right that the resistor pack was u/s - depending on which resistor burns out determines how many fan settings don't work. If you still have the suspect one,
I hope to have some replacement resistors available soon - see the group buy.
