Head gasket failures - why so many?
Re: Head gasket failures - why so many?
Postby tigerdog » Thu 09.06.2011, 22:30
I've read there are a couple of additional factors in head bolt (re-)torquing. Apparently, some designs/materials assume the bolts will stretch slightly when properly torqued the 1st time; additional re-torquing doesn't take this into account and thus improperly tightens the head and possibly weakens the bolt. Anyone have thoughts on these lines?
Postby Specky » Thu 09.06.2011, 22:48
I look at it from a slightly different perspective,
A retorque is pointless, a torque check let's you know what's happened.
You shouldn't be tightening anything, no torquing, no retorqing.
I've done hundreds and been bored to death doing them.
For the laymen,
you know what your torque figure was when you put the head on. ( see the manual)
These figures now quoted are to be used as an example:-
Set your torque wrench up to say 5Nm,
Tq the head in the required pattern, nothing should move, then it's on to 10Nm in the required pattern, and so on a so forth until you get to the required final torque figure. Nothing should move and the torque should not have dropped. If at any stage some thing moves, "stop" have a think, if it a close torque to what you require you can continue to torque up the bolt to the correct value. Our heads are torqued in two stages and I'd say if your in the correct window your safe.
Postby Brit-Car-Nut » Fri 10.06.2011, 05:23
You are right that a lot of engines stretch the bolts during the torque process but then you should NEVER re-use them. The Fiero head bolts are like that.
Unfortunately, some head gaskets have a sealer built in that melts during the first runs and the head gasket becoes thinner, so the torque needs to be re-done to keep the pressure correct.
I haven't looked at the Lotus specs or requirements, so won't know what Isuzu / Lotus requires in regards to bolts or torque/retorque,
I am looking for an original factory service manual for the Isuzu Engine so I can follow it when I start on the engine phase.
Postby RayD » Fri 10.06.2011, 08:59
Specky wrote:
... a torque check let's you know what's happened.
Dave,
At what point do you carry out this proceedure ... and is there any recommendations on temperature.
Ray
RayD
Postby Specky » Fri 10.06.2011, 09:46
It's a grey area as there is nothing laid down in the lotus book, but personally I'm gonna give it a couple of 100 miles, it'll give everything time to bed in and settle.
As to temperature, I'm going for cold as this is the only torque value I know.
Postby Monty » Fri 10.06.2011, 11:53
If your using the OME HG then it doesn`t really need a recheck (although i did recheck mine after 500miles) and our head bolts and not the stretch type so can be reused :wink:
Postby racerstev » Fri 10.06.2011, 13:53
IMHO composite gaskets should get a retorque, MLS gaskets shouldn't need it.
The last 2 I had apart failed on the oil drain, seems the rubber gasket pulled away from the head gasket itself
causing a leak. This will give you a oil leak between the head and block under the CAS.
racerstev
Postby Brit-Car-Nut » Fri 10.06.2011, 14:01
British Leyland had us retorque the heads at the PDI and at the 1,000 mile Checkup.
I know they were having a lot of trouble with help back then and the engines were being assembled at BL.
I think they were afraid some would get out without being torqued at all so we were supposed to catch that.
They also had just switched from a copper sandwich head gasket to a fully composite one and maybe that was their scare.
Postby GeoffSmith » Fri 10.06.2011, 14:36
FWIW I thought that re-torquing was more appropriate to older (e.g. asbestos) gaskets and that hot/cold re-torquing was related to aluminium blocks/heads which have twice as much thermal expansion.
Postby DeeAitch » Fri 10.06.2011, 19:18
GeoffSmith wrote:FWIW I thought that re-torquing was more appropriate to older (e.g. asbestos) gaskets and that hot/cold re-torquing was related to aluminium blocks/heads which have twice as much thermal expansion.
I tend to agree. IIRC it used to be a requirement of the first service back in the good old days, when we had to adhere to crazy running in procedures and oil changes after 500 miles or so (there I go giving my age away :shock: )
I have never seen it in any recent service schedule - for sure it is not in ours so I can't imagine it was ever done by the dealer.
I have a fair bit of understanding when it comes to bolt torques etc - there was a nice ding dong a few years back when I said it was not a good idea to put copaslip on threads of suspension fasteners!
IMHO torque works by putting the bolt in tension no matter which fastener you look at. This in effect means stretching the bolt, even if the amount is minuscule. In fact a lot of head bolts these days are tightened by measuring the angle of rotation and no torque figure is quoted other than a low one used as a starting point. This ensures the bolt is subjected to the desired amount of 'stretch' in order to induce the correct tension required to clamp the head down onto the block.
Regarding so called 'strech' bolts I believe these are similar to bolts used in high pressure off shore work which are in fact tensioned, or stretched, by specialist hydraulic equipment. The nut is then rotated to something like 'finger tight'. This means the bolt is then subjected to a pre-determine tension, sometimes as high as 80% of yield. It is not possible to accurately get to this level of tension by torquing, as torque is affected by lots of variables such as thread finish and friction, hence the discussion on Copaslip :idea: If you are aiming for 80% of yield it is very easy to over torque even an M12 bolt to the point where it shears if it is lubricated and the torque specified is for a dry condition.
Anyway enough of my ramblings. As ever, this is an interesting debate and I suspect we will not get a definitive answer. For sure I now wish I had at least given it a go before resigning myself to a HG change!
Specky, I'm a little confused. Your first reply suggested you will re-torque but the next post says re-torquing is pointless. Do you refer to backing of 1/4 turn first?
Monty - did the bolts move when you re-torqued them? If so this would indicate the gasket had given way a little after 500 or so miles.
FWIW checking the old gasket does not reveal any obvious leak point but the rubber seal sections were not in the best of health as per racerstev's findings.
For now I'm driving with little or no boost until I make my mind up. 500 miles is up today so it's coming up to decision time!
DeeAitch
Postby Brit-Car-Nut » Fri 10.06.2011, 19:42
Can someone put up a set of pictures of the Turbo HG with a decent focus and downloadable to review in detail?
I seem to remember someone saying the Turbo HG had a round passage in one corner instead of the kidney shaped one in the NA HG.
Maybe it was a water or oil passage, but I am interested to know if the matching holes in the block and head are round or kidney shaped as if it is a reinforced part of the gasket, then it needs to be bounded completely on both sides to work.
I looked up the part number for the head and Lotus uses the same head for both NA and Turbo engine. FelPro offers several different HGs that are the same design but different material and different approaches to weak spots - water passages and the like.
Since I don't have a head or block in my posession, I was wondering what the holes in the head and block look like compared to those in the "Official Lotus" HG.
With a lot of chatter about aftermarket gaskets being junk, I was just curious.
Thanks.
Postby Specky » Fri 10.06.2011, 22:22
I've posted pictures on here of both head gaskets and there differences..
Now where is it...
Postby Specky » Fri 10.06.2011, 22:28
Postby Brit-Car-Nut » Fri 10.06.2011, 22:34
Thank you.
Postby RayD » Sun 12.06.2011, 11:08
I hadn’t realised it qualified as a ding dong Dave … I only made one post and everyone else seemed to agree with you. I wouldn’t base any decision on re-torquing head bolts on anything that was said in that thread.
Using angle of rotation to pass on the tightening requirements is still using torque … I imagine the main reason for introducing it was to cancel out the effects of lubrication.
While in theory bolts are tending to stretch it’s not something anyone starting out needs to be concerned about. It’s better to focus on the joint you are making. There’ll be plenty of occasions when the bolts aren’t stretching at all … when they would simply pull all the threads out before you reached that point.
It is not a good idea to slacken the head bolts off after a “running in” period.
As far as checking the torque without slackening the bolts as Dave (Specky) suggests … while there’s no harm in it I’m not sure what it tells you. If they always seem to be at the intended torque it could be as John C says due to “static friction”. If they always turn out to be 3lbf.ft less it might be how it was intended.
One thing I would do differently … on an head gasket situation where you have a lot of bolts over a large area … is, rather than use a 2 stage tightening procedure I’d split it up into as many stages as practicable so that you were creeping up more slowly on the proper torque or degree of rotation.
Ray
RayD
Postby bobbrown » Sun 12.06.2011, 13:36
There are several reasons they went to an angular torque, one is it is easy to control the actual amount of clamp load you are imposing on the head.
If you are using a torque wrench and stop moving before you get to the set figure you may find that when you start to move the bolt it appears to be at the correct torque. This is due to friction and the way it behaves, you have two figures for friction, static and kinetic for example.
Steel on steel dry 0.74 static 0.57 kinetic
Metal on metal lubricated 0.15 static 0.6 kinetic
These are just approximate figures to show the differences
As you can see the difference is a reasonable amount so if you are using a torque wrench do not try to sneak up on the value it is better to be slightly over than under.
If you are unsure back the bolt off and try again and I do not think increasing the torque in small steps is a good idea either as the same situation can occur better one fluid movement from one torque setting to the next.
Never mind the fact that torque wrenches have a tolerance usually +/- 4% and it is better to use a torque wrench that it working mid range not at its limits either end of the scale as the tolerances can be further out in these areas.
If you want to see the difference for your self just try tightening a bolt to a set torque and then see how much more torque is required to get it to move again.
When they use TTY bolts most of this error is eliminated as the bolt is turned a set amount after the initial starting point and they tend to run the bolt in to its elastic region such that the bolt is at its maximum clamping force. With this method you get to the same load across all the bolts reasonably accurately as they should all be in the same elastic region and the angle is not so critical to reaching this point as there is probably 30 degrees margin of error.
As DeeAitch said in a lot of cases where the bolts become large like on big diesel engines head bolts they are tightened all together with hydraulic jacks and the nuts turned down by hand this ensures an even load and the clamping force on each bolt is the same. They use the same method on a lot of the other bolts like bottom end, main bearing caps etc.
Head gaskets will fail on any engine, when is the big question and it is down to a lot a variables but one reason is the head is not static it all moves not a larger amount but it moves, even the expansion rates between a cast iron block and an aluminium head will cause movement, also the engine flexes and can actually be seen on big diesel engines.
As for re-torquing the head if the manual does not mention it then I see no reason to do so.
Bob
Pacific Blue N/A
bobbrown
Postby Specky » Sun 12.06.2011, 15:37
You’ve hit the nail on the head Ray by saying there’s no harm in doing it, that’s the point,like I said earlier, It’s not about torquing or retorqing, it’s about checking. I agree 3lbf may be how it's intended but what if, the two right hand bolts move on your first setting what does it tell you?
There are several reasons as to why and what it can show up-
As john C says "static friction", I totally accept this, It's well know and documented, but you’re not checking what the torque is, your checking for the abnormality.
Here’s a few reasons to check:-
you'll have gasket creep and gasket migration.
If you torque anything up, go back to it 48 hours later the torque can drastically drop.
Then there's all the other issues, Especially if reusing items:-
stretched bolts, soft bolts, sheared bolts, migration and movement of parts causing loss of torque.
If there was oil or grease under the head of the bolts or mating faces, you'll initially get a hydraulic lock that will release over time.
you may have trapped something, fitted a duff bit of kit.
There's all manner of scenarios that can cause the torque to drop.
It's all just standard engineering practices, and like Bob says the error on torque wrenches is quite big, we have a work around that negates some of the errors. We calibrate ours every 3 months and it's a dull boring job doing umpteen torque wrenches and going through the whole range and working out the percentage error, but we never trust the gauge on the torque wrench, we use the guage as a guide to set it up, the actual desired torque is set up on an analyser before hand. At least everyone is torquing to the same value. So it doesn't really matter what ever tool they are using. The calibration of the analyser is a lot finer.
What Bob says about the 4% is huge, epecially if you're working in a pair undertaking a large task, say torquing in a clock ray method around a large piece of machinery, a possible 8% error between the left handside to the right handside ... :shock:
A few things that grip my s**t are people who never back torque wrenches off after using them, and people who torque something up, and then do it again just to check...That "Click-Click" sound....Why!!!
So from my point of view, It's not about Torquing or retorquing, It's about checking, you're looking for the error which invariably is going to happen sometime and if you can spot it before it happens, all well and good.
Hope that makes sense.. :D
Postby RayD » Sun 12.06.2011, 16:05
I agree with you Bob,
If you disagree with my point about torqueing up in stages I haven’t explained properly.
Torqueing a number of bolts over a large area in order to get an even compression is best done in stages … from finger tight onwards … with the torque wrench set properly for each stage.
I’m not sure why you used the word “either” at the end … it gives the impression you are reeling off a list of things you disagree with … have I missed something?
With people using the Internet to search for answers, any advice I’m giving is aimed at people who haven’t yet got to grips with a particular subject … I’m not trying to change your mind, or anyone else’s who know what they are doing.
Ray
RayD
Postby RayD » Sun 12.06.2011, 16:21
I’m sure you are right Dave and particularly with the business you’re in.
When I got half way down your post I was thinking I must mention the point about backing torque wrenches off … but you beat me to it …
if you watch closely the same people always turn it a bit further as well. :D
Ray
RayD
Postby bobbrown » Sun 12.06.2011, 17:07
Ray
I was not disagreeing with applying torque in stages but if the increments are too small the difference between static and kinetic friction would mean that the torque wrench would go click (assuming that type) before the bolt moved.
When you said "I’d split it up into as many stages as practicable so that you were creeping up more slowly on the proper torque or degree of rotation" you did not say what was practicable. In my view increments that are too low are prone to errors and engine manufactureres recommendation is two steps and there is probably a good reason.
How can either imply a list? its one ot the other, both, Oh! I see a list of 2.
Bob
Pacific Blue N/A
bobbrown
Return to Engine
