JonT wrote:In the absence of being able to find a replacement, has anyone fitted a blanking plate? (I'm thinking a thin plate between the inlet manifold and the EGR valve).
As a diagnostic method to see if this is the cause of your 'not making expected boost' then I'd go along with fitting a thin blanking plate between inlet manifold and EGR. GeoffSmith (not a numpty) also suggested it earlier on.
The sensor there would misread as there wouldn't be any flow from the exhaust but I don't even know if it's used by the ECU as most of the pictures from other peoples EGR valves don't seem to show one (to complicate things, my car had a replacement engine fitted in 1995 but it is a non-cat engine).
I'm only speculating with what follows but here goes:
The sensor on the EGR is only used with California spec cars AND with Ca spec ECUs. Lotus used the same loom and parts on lots of different spec/destination cars.
The EGR valve is operated via a solenoid identical to the boost control solenoid. So a vacuum take-off from below the plenum intake goes to the EGR solenoid and another vacuum pipe then goes from the solenoid to the top-hat diaphragm on the EGR valve. When the coolant temp is >30C, MAP says the engine is under load, RPMs are > 1000, acceleration mode is On, then the solenoid switch opens and allows the vacuum from the plenum intake to pass to the EGR diaphragm and open the EGR valve. On non Ca. spec cars the ECU doesn't know, or care, about the sensor on the EGR -- it only knows, or cares, about whether the EGR control solenoid is open or closed. It reports its position (On/Off) to the ECU and Elanscan (Flag 12 Bit 5)
So I don't think it will do any harm to blank it off but additionally you shouldn't get a fault code or CEL because the solenoid is still reporting its position correctly even though the EGR isn't actually passing gas to the intake.
My only concern in the longer term is the EGR pipe is taking exhaust from the exhaust manifold (before the turbo) and if this is leaking to atmosphere via the leaky EGR valve then this may reduce the turbo spooling (loosing exhaust pressure to atmosphere). If the blank plate works, I'd be very tempted to remove the EGR pipe and blank plug the EGR pipe at the exhaust manifold.
All the above is my opinion, do at your own risk, worth what you paid for it, etc.
