I can just about manage one click using all my strength with both hands
what about slackening off the cables a tad, it does sound like there's not enough adjustment
Plenty of slack
handbrake no easier than before, 2 hands = 2-3 clicks.
bobbrown wrote:I'm not missing your point just do not understand why and what it is supposed to prove.
bobbrown wrote:
… if the lever on the caliper is extended then the travel on the hand brake lever is extended and the relative distance between clicks at the caliper is reduced. the only thing that changes is the mechanical advantage.
bobbrown wrote:Or are you saying the new design does not work in some way …
bobbrown wrote:
….. if you are implying the handbrake should be easier to apply, what do you think I'm trying to do.
On page 10 RayD wrote:Is it possible to quantify how much effort is needed to operate the caliper lever without using the cable … on an un-installed caliper can you for instance push the lever through its full travel using your thumb … and what’s it like with the fluid in, and the pads out … will it operate by hand ... would the mechanism stand a longer lever and the cable housing moving out, I wonder?
Alan_C wrote:Do you have these calipers or any intentions of purchasing any? I'm asking as it seems, not to be impolite, that you tend to confuse the situation and contest much of what has been said, especially by Bob. I can see where you're coming from, especially regarding the proposed extended length caliper lever, but it's all very simple. A longer lever at the caliper end will require a longer pull of the handbrake lever with a corresponding lower required force to apply. The last thing this topic needs is more confusion, those of us who already have the calipers are confused and upset about it enough.
Alan_C wrote: I'm asking as it seems, not to be impolite, that you tend to confuse the situation and contest much of what has been said, especially by Bob. I can see where you're coming from, especially regarding the proposed extended length caliper lever, but it's all very simple. A longer lever at the caliper end will require a longer pull of the handbrake lever with a corresponding lower required force to apply. The last thing this topic needs is more confusion, those of us who already have the calipers are confused and upset about it enough.
